Restore Axis Position on Power Up
Service Home Service Alerts/News Restore Axis Position on Power Up
December 01, 2022 Restore Axis Position on Power Up
 Be advised that the information displayed may not be current and valid. Service News information is subject to change.
Machines with Software Version 100.21.000.1000 and later will have the following behavior at Power Up.
  • ST-10/15 built 8/1/2022 and later.
If a machine has been Zero Returned and all axes have been homed. If there is no axis motion caused by external force when the machine is powered off. At power up, the machine will consider itself zeroed and the machine axes will not need to be Zero Returned.
The Press [POWER UP] step will have a green check mark[1] on the Haas Start Up page. After cycling the door and releasing the Emergency Stop and pressing [RESET] to clear alarms, the machine is safe to operate. If the machine axes are homed[2] and [POWER UP] is pressed or [ZERO RETURN] [ALL] is pressed, nothing will display.
If the machine axes are not at home and [POWER UP] is pressed or [ZERO RETURN] [ALL] is pressed, a pop-up will display and the machine axes will have green check marks[3], this shows that the axes do not have to be homed.
