    26. Українська
    26. Українська
UMC-350HD-EDU
  1. Vertical Mills
  2. Universal Machines
  3. UMC-350HD-EDU
UMC-350HD-EDU
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
5-Axis CNC Vertical Machining Center for Education, with 15" x 14" x 12" travels, 40 taper
The UMC-350HD-EDU is a specially priced education-edition machine that is perfect for schools as a first step into 5-axis CNC machining and training. It combines the 40-taper performance of our DM-1 Drill/Mill Center with the versatility of our TRT210 dual-axis rotary to create a small UMC that’s perfect for teaching the fundamentals of 3+2 and simultaneous 5-axis machining. And the machine’s compact footprint easily fits into most training facilities.
  • 5-axis simultaneous machining
  • Available exclusively for educational institutions
  • 40-taper inline direct-drive spindle
  • 18+1 side-mount tool changer
  • Includes Wireless Intuitive Probing System
See Available Stock
Current Lead Time
  • 40 Taper
  • 5 Axis
  • 10k RPM
  • 18+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Automation
  • Machine Info
Travels S.A.E METRIC
X Axis 15.00 in 381 mm
Y Axis 14.00 in 356 mm
Z Axis 12.00 in 305 mm
Spindle Nose to Platter (~ max) 16.0 in 406 mm
Spindle Nose to Platter (~ min) 4.0 in 102 mm
Trunnion S.A.E METRIC
Platter Diameter 9.10 in 230 mm
Max Weight on Platter 100 lb 45.4 kg
Spindle S.A.E METRIC
Max Rating 15.0 hp 11.2 kW
Max Speed 10000 rpm 10000 rpm
Max Torque 46.0 ft-lbf @ 1700 rpm 62.0 Nm @ 1700 rpm
Taper CT or BT 40 CT or BT 40
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Air Cooled Air Cooled
B Axis - Tilt S.A.E METRIC
Travel 120 ° to 45- ° 120 ° to 45- °
Max Speed 80 °/sec 80 °/sec
Torque (Continuous) 300 ft-lbf 407 Nm
Brake Torque 425 ft-lbf 576 Nm
Accuracy (±) ± 25.0 arc-sec ± 25.0 arc-sec
Repeatability 10 arc-sec 10 arc-sec
C Axis - Rotation S.A.E METRIC
Travel 360 ° 360 °
Max Speed 100 °/sec 100 °/sec
Torque (Continuous) 210 ft-lbf 285 Nm
Brake Torque 200 ft-lbf 271 Nm
Max Part Swing 14.5 in 368 mm
Accuracy (±) ± 15.0 arc-sec ± 15.0 arc-sec
Feedrates S.A.E METRIC
Max Cutting 1200 ipm 30.5 m/min
Rapids on X 2400 ipm 61.0 m/min
Rapids on Y 2400 ipm 61.0 m/min
Rapids on Z 2400 ipm 61.0 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2550 lbf 11343 N
Max Thrust Y 2550 lbf 11343 N
Max Thrust Z 4200 lbf 18683 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 18+1 18+1
Max Tool Diameter (full)** 2.5 in 64 mm
Max Tool Length (from gage line) 7.00 in 7.00 in
Chip-to-Chip (avg) 1.60 s 1.60 s
Tapping S.A.E METRIC
Max Tapping Speed 5000 rpm 5000 rpm
General S.A.E METRIC
Coolant Capacity 55 gal 208 L
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 10000 rpm 10000 rpm
Spindle Power 15.0 hp 11.2 kW
Domestic Pallet 102.0 in x 91.0 in x 98.5 in 259 cm x 231 cm x 250 cm
Export Pallet 102.0 in x 91.0 in x 98.5 in 259 cm x 231 cm x 250 cm
Weight 6420 lb 2915.0 kg
NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
*Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
**Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
† Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
Standard Features
  • 10,000-rpm Spindle
  • 18+1 Side-Mount Tool Changer
  • Wireless Intuitive Probing System
  • Variable Flow Coolant
  • 55-Gallon Coolant Tank
  • Control Touch Screen
  • Ethernet Interface
  • Power Surge Protection
  • Advanced Tool Management
  • Media Display M-Code; M130
  • Safe Run
  • HaasDrop
  • Dynamic Work Offsets and Tool Center Point Control
  • Rigid Tapping
  • Internal High-Voltage Isolated Transformer
  • Convenience Package
  • Phone Charging Stand
  • 230 mm Platter
Warranty
  • 1-Year Standard Warranty
  • 6-Month Standard Warranty
Available Options
Automation Options
ANSWERS TO YOUR CONCERNS ABOUT ADDING A HAAS ROBOT: It won’t take up much space, cost a ton of money, or take weeks to integrate.
SPACE EFFICIENT
COST EFFECTIVE
EASY TO INTEGRATE
EASY TO LEARN
AVAILABLE OPTIONS
RELATED PRODUCTS
Standard Features
  • Safe Run
  • HaasDrop
  • Rigid Tapping
  • 230 mm Platter
Warranty
Available Options
Automation Options
Platter Options
SEVERAL PLATTER STYLES ARE AVAILABLE
Bolt-Hole
A1-6
Zero Point
Product Image
T-Slot Platter
Optional platter for the TRT210
    CNY ONLY
Learn More Build & Price
Product Image
A1-6 Platter
    CNY ONLY
Complete Workholding Solutions
JERGENS 130 MM VISE KIT
Manual Clamping
  • Haas by Jergens 5" self-centering vise
  • Machinable aluminum and steel vise jaws
  • Adapter plate for bolt-hole platter
  • Mounting hardware
LEARN MORE
75 MM AIR VISE KIT
Automatic Clamping
  • Includes foot pedal and M-codes
  • Includes pneumatic union and hardware
  • Hardened-steel jaws with serrations
  • Replacement hard and soft jaws available
LEARN MORE
ZERO POINT KIT
Automatic Clamping
  • Accurate, repeatable fixture locating
  • Zero Point chuck, plate, and pull stud
  • Pre-installed pneumatic union and hardware
LEARN MORE
  • 3D Model (ZIP) UMC-350HD + HRP-1
  • Installation Guide
  • Layout Drawing
  • Layout Drawing UMC-350HD + HRP-1
  • Torque Chart
  • Operator’s Manual
  • Vise Options & Configurations chart
  • Automation Options And Configurations chart
UMC COMPARISON – Work Envelope ≠ Machine Travels
In 5-axis machining, your part and workholding must be able to rotate and tilt within the workspace, allowing you to reach all areas of the part, without interference or collisions. This yields a cylindrical work envelope that is smaller than the machine travels.
DOWNLOAD COMPARISON
HAAS VISE OPTIONS AND CONFIGURATIONS CHART
AIR VISES | HYDRAULIC VISES
RELATED PRODUCTS
3-AXIS MACHINE
Haas Mini Mill EDU
Mini Mill - EDU
Mini CNC Vertical Mill Exclusively for Education, with 16" x 14" x 15" travels
  • 40 Taper
  • 3 Axis
  • 6k RPM
  • 1 Tool Capacity
    CNY ONLY
TURNING OPTION
Haas TL-1-EDU
TL-1-EDU
CNC Toolroom Lathe Exclusively for Education, with 16" x 30" max capacity
  • A2-5 Nose Chuck Size
  • 2.3" Bar Capacity
  • 1.8k RPM
  • 10 hp Power
    CNY ONLY
LARGER WORK ENVELOPE
Haas UMC-500
UMC-500
5-Axis CNC Vertical Machining Center with 24" x 16" x 16" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Build & Price
Get Started
Need More Information?
