CL-1
PRE-INSTALLATION [GUIDE]
CL-1
    CNY ONLY
CNC Chucker Lathe with 1" bar capacity
  • 5C Nose Chuck Size
  • 1.0" Bar Capacity
  • 6k RPM
  • 5 hp Power
  • Layout Drawing
  • Lifting Instructions
  • Additional Resources
Pre-Installation Checklist
STEP-BY-STEP INSTALLATION GUIDE
Foundation
You must put your machine on a solid and stable concrete foundation. The standard 6" (150 mm) concrete floor in industrial buildings is usually sufficient. However, heavy and complex machines, such as Large-Frame mills and UMCs, may require a 12" (300 mm) concrete foundation, to ensure accurate geometry. Refer to these specifications:
  • Continuous slab – DO NOT place machines across expansion joints or cracks.
☑ Anchoring
For best cutting performance, Haas recommends anchoring your machine. Click here to view anchoring kits for your machine
☑ Machine Placement
☑ Optional Component Location
  • External Transformers.
Layout Drawing
Download Machine Layout Drawing (PDF)
The CL-1 is not suitable for overhead lifting. It does not have built-in lifting provisions, and must be lifted by forklift.
Air Required† 1 scfm @ 70 psi 28.0 L/min @ 4.8 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Air Pressure Min 70 psi 4.8 bar
Spindle Speed 6000 rpm 6000 rpm
Drive System Direct Speed, Belt Drive Direct Speed, Belt Drive
Spindle Power 5.0 hp 3.7 kW
Input AC Voltage (1 Phase) 220 VAC 220 VAC
Full Load Amps (1 Phase) 16 A 16 A
Full Load Amps (3 Phase) - Low 12 A 12 A
Domestic Pallet 78.0 in x 62.0 in x 80.0 in 199 cm x 157 cm x 204 cm
Export Pallet 78.0 in x 62.0 in x 80.0 in 199 cm x 157 cm x 204 cm
Weight 1940 lb 917.0 kg
Domestic Pallet w/1 m Bar Feeder 99 in x 54 in x 82 in 252 cm x 137 cm x 208 cm
Export Pallet w/1 m Bar Feeder 99 in x 54 in x 82 in 252 cm x 137 cm x 208 cm
Weight w/1 m Bar Feeder 2060 lb 935 kg
Domestic Pallet w/6' Bar Feeder 120 in x 54 in x 82 in 305 cm x 137 cm x 208 cm
Export Pallet w/6' Bar Feeder 120 in x 54 in x 82 in 305 cm x 137 cm x 208 cm
Weight w/6' Bar Feeder 2240 lb 1017 kg
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines, CL-1, and CM-1. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. Verify the power requirement before running power for your machine.
Caution:
    • soluble oil coolant
    • semi-synthetic coolant
    • synthetic coolant
General
  • Refer to the Machine Layout Drawing for the location of the machine's electrical input.
440 V Power *
  • Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines, CL-1, and CM-1.
Ground
Three-Phase Power
Single-Phase Power
Wire Size
Service Breaker
Phase Converters
  • Anchoring Instructions
  • Video Library
  • Operator’s Manual
  • Service
