CL-1 Installation Guide
Service Home How To Procedures CL-1 Installation Guide
Recently Updated Last updated: 02/10/2026
- Jump to Section - 1. Introduction 2. Removal of Rust Inhibitor 3. Air Connection 4. Electrical Connections 5.  (8 steps) 6. Removal of Shipping Brackets (1 step) 7. Machine Leveling (2 steps) 8. Spindle Sweep Check (2 steps) 9. Tool Turret Alignment Check (2 steps) 10. Spindle Centerline Check (1 step) 11. Machine Operation (9 steps) 12. Lathe Maintenance Schedule Back to Top
This procedure will guide you through the installation of a CL-1
Tools required:
  • Precision Machinist Level, 0.0005" Division
  • Precision Spindle Test Bar, 8" Long
  • 3/4 " socket and ratchet
  • 1-1/2" Wrench
  • Tape Measure
  • 0.0005" or 1 micron indicator
To safely and effectively remove rust inhibitor from way covers and other non-painted surfaces:
Initial Scraping
  • Use a plastic scraper to remove the bulk of the rust inhibitor.
  • Avoid using metal tools to prevent scratching or damaging the surface.
 Important: Do not use scotch-brite or metal scrapers, these will scratch the way covers.
Chemical Cleaning
  • Spray the affected areas with a heavy-duty citrus cleaner or Simple Green.
  • Ensure full coverage of all non-painted surfaces coated with rust inhibitor.
Soak Time
  • Allow the cleaner to soak for several minutes to loosen remaining residue.
Wipe Down
  • Use a clean shop towel to thoroughly wipe off the softened rust inhibitor.
Rust Proofing
  • Apply mineral spirits or WD-40 to all exposed metal surfaces to prevent future rust formation.
Important: Always wear gloves and eye protection when handling chemical cleaners. Dispose of used towels and cleaning agents according to local environmental regulations.
 Important: To avoid any contamination of the way cover seals with the sticky residue. Do not move any of the axes until all the rust inhibitor has been removed.
Rust Inhibitor - Safety Data Sheet (SDS)
Air Connection
Connect the air supply at the lube panel.
 Note: For air requirements refer to the decal that is located on the lube cabinet door.
Follow the Air Gun and Hose Installation procedure to install or replace the Air Gun.
 Note: Some installation kits will come with a spare air gun assembly.
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
Initial Control Inspection
Danger: At this point, there should be no electrical connection to the machine. Electrical panel must be closed and secured. When main switch is on, there is HIGH VOLTAGE throughout the electrical panel (including the circuit boards and logic circuits) and some components operate at high temperatures. Therefore, exercise extreme caution when working in the panel.
  • Set the main breaker switch at the upper right of the electrical panel on the back of the machine to OFF.
  • Using a screwdriver, unlock the two latches on the panel door, unlock the cabinet with the key and open the door.
  • Take sufficient time to check all the components and connectors associated with the circuit boards. Look for any cables that have become disconnected, look for any signs damage and loose parts in the bottom of the panel box. If there are any signs that the machine was mishandled, call the factory before proceeding.
1-Phase Machines: Insert each power lead into the wire cover.  Connect the two power leads to L1 and L3 terminals on top of the main circuit breaker.
3-Phase Machines: Insert each power lead into the wire cover.  Connect the three power leads to L1, L2 and L3 terminals on top of the main circuit breaker.
Connect the separate ground line to the ground bus to the left of the terminals.
For 3-phase machines, check to see what type of power configuration is supplying the machine. Take voltage measurements of each power lead to ground line. Then refer to RD0084 - Input Power Configurations to determine which power lead should be connected to the L1 terminal based of the voltage readings and power configuration.
Refer to Haas Main Circuit Breaker - Torque Specifications for what value to torque the circuit breaker power leads.
 Note: Make sure that the leads actually go into the terminal-block clamps . (A poor connection will cause the machine to run intermittently or have other problems, such as servo overloads.) To check, simply pull on the wires after the screws are tightened.
After the line voltage is connected to the machine, make sure that main circuit breaker (at top-right of rear cabinet) is OFF . Remove the Lockout / Tagout and Turn ON the power at the source. Using a digital voltmeter and appropriate safety procedures:
1-Phase Machines: Measure the AC voltage across L1 & L3 at the main circuit breaker.  The AC voltage must be between 220 - 250 volts .
Note: Lower or higher than this voltage can generate low/high voltage alarms.
3-Phase Machines : Measure the AC voltage between all three pair phases at the main circuit breaker.
The AC voltage must be between 195 and 260 volts (360 and 480 volts for high voltage option).
SMinimill - Reboot: The AC voltage must be between 198 and 242 volts for machines without a high voltage transformer.  Refer to the Minimill/SMinimill - Identification document.
 Note: Wide voltage fluctuations are common in many industrial areas; minimum and maximum voltage supplied to a machine while it is in operation must be known. U.S. National Electrical Code specifies that machines should operate with a variation of +5% to -5% around an average supply voltage. If problems with line voltage occur, or low line voltage is suspected, an external transformer may be used. If you suspect voltage problems, voltage should be checked every hour or two during a typical day to be sure it does not fluctuate more than +5% or -5% from an average.
Important: With the main circuit breaker turned OFF.
Check the transformer taps at the bottom-right corner of the rear cabinet.
1-Phase Machines: The input voltage cable must be moved to the connector which corresponds to the average voltage measured in the above step.
3-Phase Machines:  The input voltage cables labeled 74, 75, and 76 must be moved to the terminal block triple which corresponds to the average voltage measured in the above step.
Transformer T5 supplies 24VAC used to power the main contactor. There are two versions of this transformer for use on a 240 and 400V machines. The 240V transformer has two input connectors located about two inches from the transformer, which allow it to be connected to either 180-220V or 221-240V.
Users that have 220V-240V RMS input power should use the connector labeled 221-240V, while users with 190-220V input power should use the connector labeled 180-220V. Failure to use the correct input connector will result in either overheating of the main contactor or failure to reliably engage the main contactor.
The 480V (option) T5 transformer has three input connectors, labeled 340-380V, 381-440V and 441-480V.
Users with 340-380V 50/60Hz power should use the 340-380V connector while users with 380V-440V 50/60Hz power should use the 381-440V connector.
Important: Set the main circuit breaker to ON. Check for evidence of problems, such as the smell of overheating components or smoke. If such problems are indicated, immediately set the main circuit breaker to OFF and call the factory before proceeding.
After the power is on, measure the voltage across the bottom terminals on the main circuit breaker. It should be the same as the measurements where the input power connects to the main breaker. If there are any problems, check the wiring.
Apply power to the control by pressing the Power-On switch on the front panel.
Check the DC Voltage and AC Line Voltage gauges in Diagnostics. The DC Voltage gauge must read between 310 - 360V. The AC Line Voltage must be between 90 and 105 percent. If the voltage is outside these limits, turn off the power and recheck steps 2 and 3. If the voltage is still outside these limits, call the factory.
Electrical power must be phased properly to avoid damage to your equipment. The Power Supply Assembly PC board incorporates a "Phase Detect" circuit with neon indicators. When the orange neon is lit (NE5), the phasing is incorrect. If the green neon is lit (NE6), the phasing is correct. If both neon indicators are lit, you have a loose wire; check the connections. Adjust phasing by setting the source power to off and then swapping L1 and L2 of the incoming power lines at the main circuit breaker.
Danger: ALL POWER TO CNC MUST BE TURNED OFF LOCKOUT-TAGOUT AT THE SOURCE PRIOR TO ADJUSTING PHASING. ALWAYS DOUBLE CHECK THE INCOMING LINES WITH AN AC VOLTAGE DETECTOR.
Turn off the power and set the main circuit breaker to OFF. Close the door, lock the latches, and turn the power back on.
Remove the key from the control cabinet and give it to the shop manager.
Activation
When the machine is properly placed and connected to both air and electrical power, it is ready for final installation (removing shipping blocks, leveling, spindle sweep, etc.) and software activation. The HFO service technician does this. Contact the local HFO to schedule the work.
IMPORTANT:  Machines equipped with motion sensors must be rough‑leveled before attempting to arm the motion sensor.  For detailed instructions, refer to Service Notification - SA0007.  Access to this document is restricted to Haas Factory Outlet personnel.
Remove the top (x2) screws [1] holding the pendant in the locked position.
Swivel the pendant out to gain access to the remaining (x2) screws [2] located near the pendant's hinge and remove them.
Inside the machine, remove the shipping bracket [3] securing the table to the spindle head.
Outside the machine, remove the last shipping bracket [4] holding the coolant tank in place.
Machine Leveling
Clean the turret and jog the X and Z-axis so the turret is on the center of travel.
Place the level on top of the turret. The long vial on the level represents the Z axis and the short vial on the level represents the X axis.
Loosen the (4x) leveling screws on the corners of the base. Make small adjustments  to leveling screws 1 and 3 to adjust the Z axis level. After each adjustment, note the position of the  bubble in the short vial.
If the position of the bubble in the short vial isn't centered, make adjustments to leveling screws 1 and 2 as required.
Repeat this process until both bubbles are in their center positions.
Adjust (x4) leveling screws to be snug against the ground.
Jog the turret towards the spindle column while observing the position of the bubble in the long vial. If the bubble is not centered, make a small adjustment to the lower corner.
Repeat this process with the turret on the other end of the machine.
Spindle Sweep Check
Insert test bar [1] into the spindle. Attach indicator [2] base to the table and the tip touching the testbar.
Find the high spot and sweep the top [3] of the testbar from the base to the tip. Record the values.
Find the high spot and sweep the side [4] of the testbar from the base to the tip. Record the values.
If the top face sweep exceeds 0.0002", break loose the spindle head bolts [1]. Adjust the indicator reading by tapping the spindle head with a mallet.
If the side face sweep exceeds 0.0002", adjust the spindle column shims [2].
Torque the spindle head bolts [1] to 110 ft-lbs.
Place the indicator mag base on the spindle head touching the top surface of the turret.
Sweep the turret surface along the Z axis [1]. Observe indicator readings.
Sweep the turret surface along the X axis [2].  Observe indicator readings.
Index the turret until Pocket 1 is facing the spindle. Move the indicator tip to the outer edge of the turret.
Sweep the turret's edge [3] at Pocket 1. Observe indicator readings.
If either turret surface readings exceed 0.001", break loose the turret casting bolts [1] and insert the necessary shims on either side of turret bolts [2].
If the turret face reading exceeds 0.001", break loose the turret casting bolts [1]. Adjust the indicator reading by tapping the casting with a mallet.
Torque the turret casting bolts [1] to 180 ft-lbs.
  IMPORTANT:Use calibrated tooling holders ONLY for squaring the tool changer.
Mount the test bar tool [1] in Pocket 1.
NOTE: Use metric (mm) tooling only when squaring metric tool changers.
Insert coaxial indicator [2] in the spindle touching the top of test bar tool [1].
Find the high spot. Sweep the X axis [3] and check the top to bottom error.
If the top to bottom error exceeds 0.002", adjust the spindle head shims accordingly. Recheck Tool Turret Alignment.
Machine Operation
Test Spindle Operation
Run the Spindle Run-In program O09220.
In the case of an unusual spindle noise, run a vibration test. For a guide on how to perform a spindle vibration test please see:
Vibration Analysis - Ethernet Interface
Vibration Analysis - RS-232 Interface
Test Coolant Operation
Fill the coolant tank with the necessary gallons of coolant in order to fill the tank.
Connect the coolant pump.
Run coolant by pressing  [COOLANT] on control pendant.
Test Door Interlocks
Press [MDI]. Type in S500 M3; Press [ENTER].
Make sure the machine IS NOT in SETUP MODE by Checking the KEY SWITCH on the side of the pendant
With the door open, press [CYCLE START]. The machine should say to close the door and press [CYCLE START].
With the door closed, press [CYCLE START]. The interlock pin should extend and the spindle starts rotating.
 IMPORTANT: With the spindle rotates, test the door locks by trying to open the door. The spindle should not stop rotating.
Test Autodoor
If the machine came with the Auto Door option, follow these steps to test the operation:
Close the CL door.
Press the Auto Door button [1] on the side of the control panel
Expected Auto Door Functions:
  • Auto Door button opens and closes door.
  • Cycle Start closes door if open.
  • In Feed Hold, pressing button will open door.
  • If a program is running, pressing auto door button will stop all machine motion and open door.
  • End of Program should open door.
Test Bar Pusher
If the machine came with the bar pusher option, remove it from its packaging and install it on your machine.
For more information on how to install a bar feeder, please see:
Bar Pusher Installation
Test Live Tooling
If the machine came with the Live Tooling option, use the following M-codes to test the functionality of the live tooling system
M133; (Live Tool Fwd)
M134; (Live Tool Rev)
M135; (Live Tool Stop)
Parts Catcher System CL.  Product of Haas CNC machine tools.
Test Parts Catcher
If the machine came with the parts catcher option, test its operation by doing the following:
In MDI mode insert the following line
M36;
Press [CYCLE START]. The parts catcher should extend.
Press [RESET]. The parts catcher should retract.
Test Wifi Camera
If the machine came with the Wifi Camera option, please see the following link for installation instructions:
Wi-fi Camera Installation
Remote Jog Handle Touch Installation
If your machine includes the Remote Jog Handle Touch option, please see the following link for installation instructions:
RJH-T Installation
Keep your Haas machines running at peak performance while avoiding unplanned downtime. A maintenance program allows you to manage your schedule rather than getting caught with untimely surprises. Please see the link below for recommended maintenance intervals.
