VM-5/50 Install Guide
PRE-INSTALLATION [GUIDE]
    CNY ONLY
50-Taper CNC Vertical Mold Machine with 50" x 26" x 25" travels
  • 50 Taper
  • 3 Axis
  • 10k RPM
  • 30+1 Tool Capacity
  • STEP-BY-STEP GUIDE
  • Layout Drawing
  • Lifting Instructions
  • Rotary Fit
  • Additional Resources
Pre-Installation Checklist
STEP-BY-STEP INSTALLATION GUIDE
Foundation
You must put your machine on a solid and stable concrete foundation. The standard 6" (150 mm) concrete floor in industrial buildings is usually sufficient. However, heavy and complex machines, such as Large-Frame mills and UMCs, may require a 12" (300 mm) concrete foundation, to ensure accurate geometry.
Refer to these specifications:
  • Continuous slab – DO NOT place machines across expansion joints or cracks.
☑ Anchoring
For best cutting performance, Haas recommends anchoring your machine. Click here to view anchoring kits for your machine
☑ Machine Placement
☑ Optional Component Location
  • External Transformers.
Layout Drawing
Download Machine Layout Drawing (PDF)
Read these instructions in their entirety before attempting to lift the machine.
WARNING:
IT IS IMPERATIVE THAT PREPARATION AND LIFTING OF THE MACHINE BE PERFORMED BY PROFESSIONAL RIGGERS. THESE INSTRUCTIONS ARE FOR REFERENCE PURPOSES ONLY.
IMPORTANT: Most – but not all* – Haas machines may be lifted by overhead crane for positioning and installation. Depending on the model, your new Haas machine may have built-in lifting provisions, or may require a lifting kit, available through your local Haas Factory Outlet (HFO), that includes required lifting brackets and hardware.
Refer to the lifting placard on the rear of the machine to locate all critical lifting points.
Specialized equipment is necessary to ensure that the machine is secure and level during lifting. When lifting the machine, slowly lift until all chains are taut, then lift the machine, making sure it stays balanced. Remove lifting brackets and hardware, if installed, before machine operation, unless otherwise noted. It is the customer’s responsibility to supply all chains and spreader bars required to properly lift the machine. Contact your local HFO for more information. Retain any supplied lifting brackets and hardware, and store them in a safe place for future use. Use only Haas-supplied lifting hardware, if required.
Refer to the lifting placard on the rear of the machine for model-specific lifting information. Attach the lifting bracket, if required, and chains as shown. Make sure that the chains do not contact the sheet metal enclosure or electrical cables. Note the use of spreader bars and lumber. Haas Automation, Inc., does not provide spreader bars or lumber.
*GR, GM, TL, CM, and CL models are not suitable for overhead lifting. They must be lifted by forklift.
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 10000 rpm 10000 rpm
Drive System 2-Speed Gearbox 2-Speed Gearbox
Spindle Power 60.0 hp 44.7 kW
Full Load Amps (3 Phase) - Low 105 A 105 A
Domestic Pallet 168.0 in x 102.0 in x 122.0 in 427 cm x 260 cm x 310 cm
Export Crate 168.0 in x 102.0 in x 130.0 in 427 cm x 260 cm x 331 cm
Weight 14920 lb 7371.0 kg
Optional Spindles
SPINDLE SPINDLE DRIVE PEAK (HP/KW) PEAK TORQUE (ft-lbs/Nm) INPUT AC VOLTAGE FULL LOAD AMPS
7.5K-rpm High-Performace Spindle Gearbox 60/44.7 392/531
220 (3 Phase)
440* (3 Phase)
105
53
10K-rpm High-Performace Spindle Gearbox 60/44.7 392/531
220 (3 Phase)
440* (3 Phase)
105
53
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines CL-1, and CM-1. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
ATTENTION! Optional high-performance spindles have a higher power requirement than the standard spindle. Verify the power requirement before running power for your machine.
Caution:
    • soluble oil coolant
    • semi-synthetic coolant
    • synthetic coolant
General
  • Refer to the Machine Layout Drawing for the location of the machine’s electrical input.
440 V Power *
  • Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines, CL-1 ,and CM-1.
Ground
Three-Phase Power
  • For Mini Mill Series machines, some options, such as Through-Spindle Coolant, require three-phase power.
Single-Phase Power
Wire Size
Service Breaker
Phase Converters
Rotary Fit Chart
TH450 VM-5/50 POSITIVE FIT
HA2TS VM-5/50 POSITIVE FIT
HA5C VM-5/50 POSITIVE FIT
HA5C2 VM-5/50 POSITIVE FIT
HA5C3 VM-5/50 POSITIVE FIT
HA5C4 VM-5/50 POSITIVE FIT
HA5CS VM-5/50 POSITIVE FIT
HRC160 VM-5/50 POSITIVE FIT
HRC210 VM-5/50 POSITIVE FIT
HRT160 VM-5/50 POSITIVE FIT
HRT160-2 VM-5/50 POSITIVE FIT
HRT160SP VM-5/50 POSITIVE FIT
HRT160SS VM-5/50 POSITIVE FIT
HRT210 VM-5/50 POSITIVE FIT
HRT210-2 VM-5/50 POSITIVE FIT
HRT210M VM-5/50 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT210SP VM-5/50 POSITIVE FIT
HRT310 VM-5/50 POSITIVE FIT
HRT310SP VM-5/50 POSITIVE FIT
HRT450 VM-5/50 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRTA5 VM-5/50 POSITIVE FIT
HRTA6 VM-5/50 POSITIVE FIT
T5C VM-5/50 POSITIVE FIT
T5C2 VM-5/50 POSITIVE FIT
T5C3 VM-5/50 POSITIVE FIT
T5C4 VM-5/50 POSITIVE FIT
TR160 VM-5/50 POSITIVE FIT
TR160-2 VM-5/50 POSITIVE FIT
TR200Y VM-5/50 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TR210 VM-5/50 POSITIVE FIT
TR310 VM-5/50 POSITIVE FIT
TRT100 VM-5/50 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TRT160 VM-5/50 POSITIVE FIT
TRT210 VM-5/50 POSITIVE FIT
TRT70 VM-5/50 POSITIVE FIT
HRT210HT VM-5/50 POSITIVE FIT
HRT210SS VM-5/50 POSITIVE FIT
TH240 VM-5/50 POSITIVE FIT
HA5C-T VM-5/50 POSITIVE FIT
HA5C3-T VM-5/50 POSITIVE FIT
HA5C4-T VM-5/50 POSITIVE FIT
TRT310 VM-5/50 POSITIVE FIT
HRT310SS VM-5/50 POSITIVE FIT
HA5C2-T VM-5/50 POSITIVE FIT
LT350 VM-5/50 POSITIVE FIT
LT260 VM-5/50 POSITIVE FIT
HRT210VM VM-5/50 POSITIVE FIT
HRT200HS VM-5/50 POSITIVE FIT
HQDA5 VM-5/50 POSITIVE FIT
HQDA6 VM-5/50 POSITIVE FIT
HRT210S VM-5/50 POSITIVE FIT
* If a rotary product is not listed, it is does not have a compatible fit with this mill.
  • Anchoring Instructions
  • Video Library
  • Operator’s Manual
  • Service
