12 - SR-Maintenance
SR - Operator / Service Manual
  • 1 - SR-Introduction
  • 2 - SR-Legal Information
  • 3 - SR-Safety
  • 4 - SR-Installation
  • 5 - SR-Control Icons
  • 6 - SR-Operation
  • 7 - SR-Programming
  • 8 - SR-G-Codes
  • 9 - SR-M-Codes
  • 10 - SR-Remote Jog Handle
  • 11 - SR-Settings
  • 12 - SR-Maintenance
  • 13 - SR-Troubleshooting
  • 12.1 SR- Series - Maintenance Schedule
  • 12.2 SR- Series - X and Y Axis Rack lubrication
  • 12.3 SR- Series - Z-axis drip tray cleaning
  • 12.4 Service Parts List
  • 12.5 SR- P - Vacuum Soft Start Breaker - Installation
  • 12.6 SR - Cable Carrier - Opening
12.1 Maintenance Schedule
SR-Series Maintenance Schedule
Revision A - 08/25
Overview
This chapter provides information on what maintenance is needed for the Haas Sheet Router.
SR-3015 / 3015P / 4020 / 4020P
Maintenance Item Interval
Clean the chips or debris from racks and guide rails
Weekly
Inspect motors and mechanical sensors.
Monthly
Inspect motors and proximity sensors.
Monthly
Grease the guide rails.
Monthly
Grease the X and Y racks.
Monthly
Clean Z-axis drip tray Weekly
Empty vacuum bags Weekly
Refill Oil Mist system (Oil PN 93-2364) As Required
Electrical Pedestal
Clean air vents / filter.
Monthly
Spindle
Clean and lubricate the spindle taper.
As Required
Axis Lubrication Pump
Inspect lubrication tank level.
Monthly
Clean the filter inside the oil reservoir. Annually
12.2 X and Y Axis Rack lubrication
SR-Series X and Y Axis Rack Lubrication
Revision A - 08/25
Overview
This procedure will demonstrate the location and application of grease to the motor racks of the SR-3015.
Note : Rack covers have been hidden in the illustrations shown in this procedure for clarity but do not need to be removed for grease application.
Note : There are 2 racks for the Y-axis and only 1 for the X-axis
Rack application
Remove the old grease by wiping the rack with a clean shop towel then apply Mobilith SHC460 to the splines on the rack using a brush or spactula.
Ensure proper coverage between the splines.
Note : Jog the axes after the re-greasing to evenly distribute the grease and remove the excess.
12.3 - Z-axis Drip Tray Cleaning
SR-Series Z-axis Drip Tray Cleaning
This procedure will demonstrate how to remove excess lubricant that drips down the Z-axis linear guides into a catch tray.
Drip Tray Removal
Remove the thumb screws [1] on the sides then slide the drip tray [2] downwards. Clean the drip tray then reinstall it back into place.
Note : When installing the drip tray ensure that it is underneath the machine sheet metal [3].
12.4 SR Service Parts List
SR - Service Parts List
Revision D - 06/2026
MACHINE PART NUMBER DESCRIPTION
SR-3015 ONLY 93-4686 DUST COLLECTOR ASSEMBLY SR-3015
93-4687 DUST COLLECTOR MOTOR SR-3015
93-4688 DUST COLLECTOR BAGS SR-3015
93-4689 Z-AXIS OFFSET PRESETTER BUTTON SR-3015
93-4690 10-METER POWER CABLE SR-3015
93-4691 CONTACTOR SR-3015
93-4692 STEPPER MOTOR SR-3015
93-4693 VFD FOR SPINDLE SR-3015
93-4694 10-METER ENCODER CABLE SR-3015
93-4695 CLOSED LOOP STEPPER DRIVE, 8A MAX SR-3015
93-4696 STEP DOWN XFMR 220VAC-70VAC SR-3015
93-4697 LUBE TANK SR-3015
93-4698 SPINDLE 18K ER25 SR-3015
93-4699 Z-AXIS LUBE MANIFOLD SR-3015
93-4700 HOME SWITCH SR-3015
93-4702 GEARBOX, 1:5 REDUCER SR-3015
93-4711 X/Y-AXIS LUBE MANIFOLD SR-3015
93-4758 24VDC INTERMEDIATE RELAY SR-3015
93-4759 INVERTER 5.5KW SR-3015
93-4760 12VDC RELAY SR-3015
93-4761 FAN 120 X 30 220VAC SR-3015
93-4766  LINEAR GUIDE Y-AXIS SR-3015
93-4776 BSCREW 20-5-343-12 SVC SR-3015
93-4797 CLAMPS SR-3015
93-4813 ALUMINUM TABLE EXTRUSIONS, SR-3015
93-5027 LINE FILTER, SR-3015
93-6151 SPINDLE BRUSH HEAD UPPER SR-3015
SR-3015 OR SR-3015P 93-4815 PROXIMITY SWITCH, SR-3015/P
93-4973  HOSE 6MM OD NYLON CLEAR KIT SR-3015/P
93-4976 LEVELING FEET SVC KIT SR-3015/P
93-4974 HOSE 4MM OD NYLON CLEAR KIT SR-3015/P
93-5419 CONDUIT SR-3015/P
93-5420 CONDUIT FLANGE CONNECTOR SR-3015/P
SR-3015P ONLY 93-4798 GEARBOX, 1:5 REDUCER SR-3015P
93-4799 SPINDLE MOUNTING PLATE SR-3015P
93-4800 OILSPEED SPINLDE SR-3015P
93-4805 TERMINAL BLOCK 600V/175A SR-3015P
93-4806 XFMR 220V/70V 1200VA SR-3015P
93-4807 ISO30 ER32 TOOL COLLECT SR-3015P
93-4809 LINEAR GUIDE 20 x 3660 Y-AXIS SR-3015P
93-4810 SPINDLE HEAD COVER SR-3015P
93-4811 BSCREW 20-5-497-12 SR-3015P
93-4812 LINEAR GUIDE 20 x 1980 X-AXIS SR-3015P
93-4818 VFD FOR SPINDLE SR-3015P
93-4819 DISTRIBUTION BLOCK SR-3015P
93-4820 AC CONTACTOR SR-3015P
93-4821 INVERTER 11KW SR-3015P
93-4822 AUTO TOOL CALIBRATOR SR-3015P
93-4825 1300-T8 LINEAR TOOL MAGAZINE SR-3015P
93-4826 AUTOMATIC LUBE TANK SR-3015P
93-4827 OIL SEPARATOR SR-3015P
93-4879 VACUUM TABLE FRONT SR-3015P
93-4880 VACUUM TABLE MIDDLE SR-3015P
93-4881 VACUUM TABLE REAR SR-3015P
93-4882 SPINDLE HEAD COVER SR-3015P
93-5408 Y-AXIS CABLE TRAY & COVER SR-3015P
93-5409 X-AXIS CABLE TRAY & COVER SR-3015P
93-5410 STAND COLUMN COVER SR-3015P
93-5411 X-AXIS CONNECTOR BRACKET SR-3015P
93-5412 SPINDLE HEAD COVER SR-3015P
93-5413 Z-AXIS CABLE CARRIER BRACKET SR-3015P
93-5414 FRONT SPINDLE COVER SR-3015P
93-5415 H35-75 CABLE CARRIER Y-AXIS SR-3015P
93-5416 H35-75 CABLE CARRIER X-AXIS SR-3015P
93-5417 H35-50 CABLE CARRIER Z-AXIS SR-3015P
93-5418 DRIP TRAY SR-3015P
93-5836 VACUUM HOSE TO MANIFOLD, SR-3015P
93-5847 Linear Guide Slider SR-3015P
93-5848 X/Y-axis Motor SR-3015P
93-5849 Z-axis Motor SR-3015P
93-5850 Dust Collector Hose SR-3015P
93-5851 Vacuum Pump Hose 5.5M SR-3015P
93-5852 AIR/OIL BLAST LOCLINE ASSY SR-3015P
93-5853 Z-Axis Coupler SR-3015P
93-6086 STAINLESS STEEL MUFFLER SR-3015P
93-6087 VACUUM FILTER SR-3015P
93-6116 VACUUM PRESSURE RELIEF VALVE SR-3015P
93-6194 PVC TABLE SECTION T12 SR-3015P
SR-4020P ONLY 93-5422 H35-75 CABLE CARRIER Y-AXIS SR-4020P
93-5423 H35-75 CABLE CARRIER X-AXIS SR-4020P
93-5424 H35-50 CABLE CARRIER Z-AXIS SR-4020P
93-5455 Y-AXIS CABLE TRAY & COVER SR-4020P
93-5456 X-AXIS CABLE TRAY & COVER SR-4020P
93-6069 VACUUM PUMP 7.5KW SR-4020P
93-6193 PVC TABLE SECTION T16 SR-4020P
SR-3015, SR-3015P, OR SR-4020P   93-5194 T-SLOT 500MM SR SERIES ROUTERS
93-5195 T-SLOT 300MM SR SERIES ROUTERS
93-5896 CONDUIT SR ROUTERS, 15 IN
93-5421 DUST COLLECTOR CASTER WHEELS
93-6130 VACUUM MANIFOLD BALL VALVE SR-P
SR-3015P or SR-4020P   93-5835 VACUUM HOSE TO TABLE, SR-3015P/4020P
93-6115 PENDANT CASTER WHEELS SR-3015P/4020P
93-6150 TRP ASSY OLISPEED SPINDLE SR-3015P
93-6202 TOOL RACK CYLINDER ASSY SR-3015P
93-6214 VACUUM TABLE PLUG SR-3015P
93-6215 DUST COLLECTOR AIR CYLINDER SR-3015P
SR-P - Vacuum Soft Start Breaker - Installation
AD0962
Revision A - 04/2026
This procedure will show how to install the soft start breaker for your SR-P machine.
SR-P machines that are having vacuum pump or soft starter issues and did not come with the soft start breaker installed on the machine are recommended to order the following the service kit. This kit is also a one to one replacement for SR-P machines that need to replace their soft start breaker:
This procedure applies to the following service kit:
  • 93-5828 SR-P VACUUM PUMP BRKR KIT
 Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
 Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
Disconnect and remove the original din rail and soft starter from the electrical cabinet.
Install the new five inch din rail [1] onto the sub-spindle servo amp fan bracket assembly using the two provided PPHS 10-32 screws.[2]
Slide on the first DIN rail end cap [1] onto the DIN rail.
Slide on the soft start breaker [2] from the service kit onto the DIN rail.
Next, slide on the soft start [3] onto the DIN rail next to the soft start breaker.
Finally, slide on the second DIN rail end cap [4] onto the DIN rail to secure the breakers and softer starter.
Connect cable 33-1595 T1/T2/T3 K1-SS [1] from the M1 contactor to the soft start breaker.
Connect cable 33-1618 SR SS TO BRKR CBL 2FT [2] from the soft start breaker to the soft starter.
AD0965
This procedure will show you how to open the cable carrier cover links for the SR machines.
Opening Cable Carrier
Use a small flat head screwdriver to push in through the right hole slot on the cable carrier cover link and pry up lightly on that side as shown in the picture.
On the left side of the cover, using the same technique, use the flat head screwdriver to lightly pry up the cover.
The cover link should look like this after prying up on both sides.
Lightly pull up on to the pried up side of the cable carrier cover link and slide it out of the cable carrier.
Repeat the steps above to take off as many cable carrier cover links as needed.
Putting On Cable Carrier Cover Links
The cable carrier link covers need to put back into the cable carrier in the correct orrientation.
The curved portion of the cable cover link cover needs to be tucked under the cover link that comes before it.
The clips on the cover link should line up with the extrudes on the cable carrier link.
Once they are lined up, push the link cover back into place.
