Bijur - Mechanical - Oil Pump - Test
Lift the plunger to hand-prime the pump until the pressure reads approximately 20 psi (1.38 bar).
 Note: If the lever arm [1] pushes up on the plunger, you cannot hand-prime the pump. Operate the spindle up to 30 minutes for the next pump cycle to complete.
In MDI mode, command the spindle to run at low speed, for example, 5 RPM.
This turns on the oil pump motor.
Stop the spindle when the lever arm drops.
Disconnect the oil feed tube [1] from the fitting [3] above the canister filter.
Pull up on the plunger [2].
Oil comes out of the fitting [3] when the pump operates correctly.
Connect the oil feed tube.
If no oil comes out of the fitting, refer to Mechanical Bijur Lube Pump Troubleshooting Guide.
In MDI mode, command the spindle to run at a low speed, for example, 5 RPM.
 Note: The Bijur mechanical pump takes approximately 30 minutes to complete a cycle.
Look at the oil pressure gauge when the plunger drops.
The oil pressure gauge shows 20 to 40 psi (1.38 - 2.75 bar). The pressure gradually decreases to 0 psi (0.0 bar) in 3-10 minutes.
