40-Taper - Inline - Tool Release Piston - Single Sensor - Replacement - AD0342
Service Home How To Procedures 40-Taper - Inline - Tool Release Piston - Single Sensor - Replacement - AD0342
Recently Updated Last updated: 11/30/2018
AD0342
Applies to machines built from: January, 2013
- Jump to Section - 1. TRP Single Sensor Replacement (1 step) 2. Applicable Parts Back to Top
This procedure tells you how to replace the single sensor TRP for a 40-taper inline vertical mill. Use this document to replace these TRP assemblies: 30-11056, 30-11860, and 30-11730. The replacement TRP does not require sensor adjustment.
Push [POWER OFF]. Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Connect a hoist to the spindle motor [1]. Remove the (4) screws [2]. Remove the spindle motor.
Remove the washers and screws [3] from the proximity sensor bracket [4]. Install the proximity sensor onto the replacement TRP assembly with the (2) screws [6]. Discard the sensor bracket [4]. Install the air hose fitting [7] and the hose clamp [8] from the used TRP assembly onto the replacement TRP assembly.
Remove the bolts [5] from the used TRP assembly. Remove the used TRP assembly and install the replacement TRP assembly. Install the spindle motor assembly.
Make sure that Parameter 278:6 SINGLE CLAMP SWITCH is set to "1."
Applicable Parts
93-30-11056    TRP BASE, 1 SWITCH MOUNTING NON ADJUSTABLE INLINE
