Tool Release Piston - Proximity Sensor - Modification - Mini Mill - TM - GR - AD0346
Service Home How To Procedures Tool Release Piston - Proximity Sensor - Modification - Mini Mill - TM - GR - AD0346
Recently Updated Last updated: 02/11/2025
AD0346
Applies to machines built from: February, 2017
- Jump to Section - 1. Introduction 2. Proximity Sensor Modification (2 steps) Back to Top
This procedure is necessary when replacing the TRP on Mini Mill, Toolroom Mill, and Gantry/Router machines made after February 2017. These machines have a different TRP casting which has one or more adjustable proximity sensors.
This procedure can also be used when replacing a TRP on machines that use both a clamp and unclamp switch.
This document applies to these following kits:
  • 93-1222 TRP BASE, 2 PROX SWITCHES WITHOUT TSC (MM,TM, GR)
 Note: Service Kit 93-1222 does not include any proximity sensors. If replacing a TRP assembly that used different types of switches, the proximity sensors will need to be ordered. For an adjustable proximity sensor, order 93-30-11169 [2].
  • 93-30-8458A TRP BASE, 2 PROX SWITCHES FOR TSC (SMM)
  • 93-30-11186 TRP BASE, 2 PROX SWITCHES FOR TSC (MM,TRM,GR)
This procedure is necessary when replacing the TRP on Mini Mill, Toolroom Mill, and Gantry/Router machines made after February 2017. These machines have a different TRP casting which has one or more adjustable proximity sensors. This procedure tells you how to make the proximity sensor non-adjustable.
Remove the TRP.
Install the replacement TRP.
Remove the proximity sensor assembly from the removed TRP.
Remove these parts from the proximity-sensor bracket:
  • (2) screws [1]
  • proximity sensor [2]
Install these parts on the replacement TRP:
  • (2) replacement screws [3]
For machines that use both clamp and unclamp switches with kit 93-1222
Mount the unclamp switch [1] on the elevated mounting surface of the TRP plate [2]. The unclamp switch is non adjustable.
Mount the adjustable switch 93-30-11169 [3] to the TRP plate on the opposite side [4].
Adjust the switch as needed so that it marks when the TRP is at it's clamped position.
Note: 93-30-11169 is not included in the 93-1222 kit and needs to be purchased separately.
