Desktop Mill and Lathes - A-62 PCB - Replacement - AD0775
Service Home How To Procedures Desktop Mill and Lathes - A-62 PCB - Replacement - AD0775
- Jump to Section - 1. Introduction 2. Replacement (4 steps) 3. Load Software Back to Top
Recently Updated Last updated: 01/21/2026
Desktop Mill and Lathe - A-62 PCB - Replacement
AD0775
This procedure will show how to replace the A62 board on a Desktop Mill and a Desktop Lathe
This procedure applies the following service kit:
  • 93-0883 SVCKIT SBC A62 8GB WIFI
 Note: This service kit will provide an upgraded A62 Board that features an update to date preinstalled Wifi Module [1].
Note: Wear anti-static gloves when handling a PCB.
Replacement
Power off the machine.
Remove the the black cover to the desktop pendant and locate the Adapter board [1] and A62 board [2].
Put an identification label on each cable that is attached to the Adapter Board [1]. This makes the installation easier. Disconnect these cables.
Remove the PCB board by unscrewing the (4) screws from the standoffs [2].
Put an identification label on each cable that is attached to the A62 board and disconnect these cables.
Remove the PCB board by unscrewing the (4) screws from the standoffs [1].
Install the replacement A62 board and reinstall the (4) screws into the standoffs.
 Caution: Carefully compare the A62 to make sure you install each cable in the correct position. If you do not correctly install each of the cables, the A62 cannot operate correctly.
Reinstall the rear panel with (8) Philips head screws.
Plug in the machine and control pendant.
Load Software
You must do a "clean" software install when you replace the A62 PCB. Update the machine software by holding the U button when powering on the machine. Refer to Software Update - (Option 5) Clean Installation - NGC.
