Dual Action Parts Catcher - Dampener Replacement - AD0676
Service Home How To Procedures Dual Action Parts Catcher - Dampener Replacement - AD0676
Dual Action Parts Catcher - Actuator Replacement - AD0676
- Jump to Section - 1. Introduction 2. Parts Catcher Identification 3. Replacement (7 steps) Back to Top
Recently Updated Last updated: 01/15/2025
AD0676
This procedure will show you how to replace the dual action parts catcher  dampener on compatible lathes.
This Document Applies to the following Service Kits:
  • 93-3771 PCAT SVC KIT 3 N.M DAMPNER
Machine Compatibility:
  • All Haas lathes equiped with a dual action parts catcher.
Single Action Parts Catcher
Replacement
Important : Turn off the machine and ensure that the air supply valve is closed. The pneumatic system needs to depressurized to be able to move the parts catcher for accessibility.
Remove the bolts [1] attaching the parts chute [2] to the rotary actuator shaft [3].
Remove the actuator shaft [1]
Remove the parts catcher plugs [1] to gain access to the hardware [2].
Remove the parts catcher cover [3].
Remove the bolts [1] that hold the actuator cover [2] .
Remove the bolts and washers [1] that hold the rotary dampener onto the actuator. Slide the rotary dampener off the actuator shaft while ensuring that the square bushing [4] is still in position.
Note : If the square bushing comes off the shaft easily it will need to replaced with the one provided. The new bushing needs to be pressed into position so the actuator will need to be removed.
Disconnect the air hoses going to the actuator quick connect fittings.Begin by removing the dampener bracket [2] and hardware [1] then remove the bolts and washers [3] that hold the actuator in place. Gently slide the actuator [5] out of the assembly.
Remove the old square bushing if it is damaged or loose then install the provided square bushing [1] by using a single drop of (green) Loctite 290 and pressing it onto the shaft until it is flush.
Note : We recommend to place the square bushing on a flat surface then gently pressing the actuator onto it.
Reassemble the components and ensure that 1 drop of (Blue) Loctite 242 is applied to the hardware.
