Keypad - Rubber-Type - Replacement - AD0654
Service Home How To Procedures Keypad - Rubber-Type - Replacement - AD0654
31.1 Keypad - Rubber-Type - Replacement
Recently Updated Last updated: 01/12/2023
AD0654
Rev A - 11/2025
This procedure tells you how to replace the rubber-type keypad on the control pendant.
Tools Required:
  • Electrostatic Discharge (ESD) strap
  • Putty knife
Parts Required:
  • 93-61-0201: Mill Keypad Rubber Type
  • 93-61-0202: Lathe Keypad Rubber Type
Removal
Press [POWER OFF].
CAUTION: Use an electrostatic discharge (ESD) strap when you touch electronic components.
Remove the rear panel from the control pendant assembly.
Remove the front panel from the control pendant assembly.
Disconnect the 24-pin ribbon cable from the keypad PCB.
Use a putty knife or a small flat screwdriver to carefully remove the rubber keypad.
Carefully pull out the 24-pin ribbon cable through the opening of the control-pendant panel.
 NOTE: Carefully remove the tamper-proof sticker attached to the 24-pin ribbon cable. See HSG-A 11/04/2025 for more information.
Insert the 24-pin ribbon cable through the opening of the control-pendant panel.
Connect the 24-pin ribbon cable into the keyboard PCB.
NOTE: Be careful when you insert the ribbon cable connector into the connector of the keypad PCB. Make sure you do not bend the pins.
Press [POWER ON].
Make sure the keypad operates.
Press [POWER OFF].
Remove the cover of the adhesive strip on the rear of the keypad. Use the upper right corner of the keypad recess to align the keypad. Press the keypad into position.
Install the rear and front covers.
Press [POWER ON].
Make sure the keypad operates. If it does not work, contact your Haas Factory Outlet.
