Spindle Encoder Cable - Replacement - NGC - AD0520
Service Home How To Procedures Spindle Encoder Cable - Replacement - NGC - AD0520
Recently Updated Last updated: 06/30/2025
AD0520
- Jump to Section - 1. Introduction 2. Replacement (5 steps) 3. Overheat Sensor Connection (2 steps) 4. Activate the Overheat Sensor 5. Verification Back to Top
This procedure shows you how to replace the spindle encoder cable on a NGC machine.  This updated cable has an overheat connection to plug into the motor overheat sensor.
This procedure applies to the following service kits:
  • 93-3037    SP MTR CLCK SW FIELD UPGRADE 12FT
  • 93-3036    SP MTR CLCK SW FIELD UPGRADE 24FT
  • 93-3035    SP MTR CLCK SW FIELD UPGRADE 18FT
  • 93-3029    SP MTR CLCK SW FIELD UPGRADE 15FT
  • 93-3027    SP MTR CLCK SW FIELD UPGRADE 25.5FT
  • 93-3026    SP MTR CLCK SW FIELD UPGRADE 4FT
  • 93-3025    SP MTR ENC M8+HOM+CLK SW UPGRADE
Replacement
Power off the machine.
Remove the spindle head cover and disconnect the spindle encoder cable from the non-contact encoder read head.
 Disconnect the encoder cable [1] from P22 [Channel 6] on the NGC Main PCB.
Remove the old spindle encoder cable.
Install the new spindle encoder cable using the same cable routing as the previous cable.
Connect the spindle encoder connector [1] to the Non-Contact encoder.
If the machine did not have a spindle motor overheat cable connection perform the following Step:
Remove the spindle motor juction box cover [1].
Locate the spindle motor overheat sensor cable inside the junction box [2].
Route the overheat sensor cable [2] through the junction box and connect it to the spindle motor terminal bracket [3].  The connector on the bracket is label "Spindle Motor Overheat".
Install the spindle motor junction cover [1].
Connect the spindle motor overheat cable [4] to the terminal bracket.
Install the spindle head cover.
Connect the encoder cable [1] to P22 [Channel 6] on the NGC Main PCB.
Install the NGC Main PCB cover and Power On the machine.
A patch is needed to activate the spindle motor overheat sensor.
Login to the HBC and download the configuration patch file and load to the control.
Verification
Run the spindle warm up program.  Verify no alarms get generated.
