Sub-Spindle Air Blast - Installation - AD0517
Service Home How To Procedures Sub-Spindle Air Blast - Installation - AD0517
Recently Updated Last updated: 11/11/2025
AD0517
- Jump to Section - 1. Introduction (1 step) 2. ST-10/15/20/25 Reboot Installation (1 step) 3. ST-10/15/20/25 Retrofit Installation (2 steps) 4. ST-30/35 Reboot Installation (1 step) 5. ST-30/35 Retrofit Installation (2 steps) 6. Sub-Spindle Air Blast Activation (1 step) 7. Sub-Spindle Operation (1 step) Back to Top
ST-10/15/20/25 machines built from 11/01/2020 and later.
  • 93-1000553 - AIR BLAST KIT SUB SPINDLE ST
ST-30/35 & DS-30Y Reboot machines built from 11/01/2020 and later.
  • 93-1000564 - AIR BLAST KIT SUB SPINDLE ST30
NOTE: For DS-30Y Non-Reboot sub-spindle auto air jet blast, refer to Auto Air Jet Blast - Installation - AD0057 for more information.
ST-10/15/20/25 machines built from 1/2019 - 10/31/2020.
  • 93-1000579 - JET AIR BLAST KIT SUB SPNDL ST RETROFIT
ST-30/35 machines built from 3/01/2020 - 10/31/2020.
  • 93-1000578 - JET AIR BLAST KIT SUB SPNDL ST30 RETROFT
Connect the compression fitting[1] to the air nozzle. Connect the air nozzle to the air line[3] with the adapter fitting[2]. Use the hose clamps to secure the the air blast assembly to the sheetmetal. Install the grommet to the sheet metal and route the braided air line into the sub-spindle casting and route it through the sub-spindle conduit and route to the CALM cabinet. Connect the end of the braided air line[4] to the adapter[5] and connect the push-to-connect fitting[6].
Route the airline into the CALM cabinet. Remove the NPT plug from the location SECOND SPINDLE AUTO JET BLAST SOLENOID (GREEN) shown on the AIR - LUBRICATION SYSTEM - PICTORIAL. Install the solenoid to the air manifold into the Connect the green hose to the solenoid.
Plug the solenoid into the TRP PRE-CHARGE/UMC AUTO WINDOW molex connector.
Remove the existing sub-spindle head sheet metal[1,2].
Install the retrofit sub-spindle head sheet metal[3,4].
Install the sub-spindle air blast mount[1] the the lifting point on the sub-spindle casting. Connect the compression fitting[2] to the air nozzle. Connect the air nozzle to the air line[4] with the adapter fitting[3]. Use the hose clamps to secure the the air blast assembly to the sheetmetal. Install the grommet to the sheet metal and route the braided air line into the sub-spindle casting and route it through the sub-spindle conduit and route to the CALM cabinet. Connect the end of the braided air line[4] to the adapter[5] and connect the push-to-connect fitting[6].
Remove the conduit clamp and bracket from the sub-spindle head sheet metal.
Remove the existing sub-spindle head sheet metal rear panel.
Install the retrofit sub-spindle head conduit clamp assembly.[1,2,3].
Install the retrofit sub-spindle head sheet metal panel.
Turn on the machine.
Login to the HAAS SERVICE PORTAL.
Download the Sub-Spindle Air Blast option configuration patch files.
Note: The option files will appear on the configuration download page after the Sub-Spindle Air Blast Kit has been ordered.  If the option does not appear contact the service department.
Load the option configuration patch file to the control.  Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
M112 and M113 activate the optional Sub-Spindle Air Blast. M112 turns the air blast on and M113 turns the air blast off. M112 Srrr Pnnn (rrr in RPM and nnn is in milliseconds) turns the air blast on for the specified time, rotates the spindle at the specified speed while the air blast is on, then turns off both the spindle and the air blast automatically.
Sub-Spindle Air Blast can be operated from the Devices tab.
