UMC Platter Seal - Replacement - AD0597
Service Home How To Procedures UMC Platter Seal - Replacement - AD0597
10.7 UMC Platter Seal - Replacement
Recently Updated Last updated: 02/15/2022
AD0597
Revision A 06/2025
This procedure outlines how to the replace the Platter Seal on all UMC Reboot series
Note: To identify which iteration of these machine models you are dealing with, refer to UMC-750 MACHINE VERSION - IDENTIFICATION.
  • 93-3577  - UMC Rotary C-AXIS Teflon Seal Kit
You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
  Only authorized personnel with the proper training and certification should do this repair procedure.
  All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
Removal
Warning: Use the proper safety process when lifting platter.
Remove the platter by following the removal section of the UMC C-Axis Platter Replacement linked below.
 WARNING: IF YOU DO NOT DISENGAGE THE BRAKE AND DISCONNECT THE LINES YOU CAN PERMANENTLY DAMAGE THE BRAKE BY REMOVING THE PLATTER.
UMC Rotary Unit – Weight Reference Guide
Carefully flip the platter over.
Using a pick or small scraper , remove the damaged seal from the platter.
Clean the bottom portion of the platter that is to come into contact with the brake assembly and groove for the seal.
Verify groove is clean and free of burrs before installing seals.
Lubricate the O-RING [2] and TEFLON SEAL [1] with Tacky Grease and install into platter groove.
Carefully flip the platter back over
Follow the installation section of the UMC C-Axis Platter Replacement linked below for the full instruction on how to correctly reinstall the platter.
