UMC Safe Zone - Calibration
Service Home How To Procedures UMC Safe Zone - Calibration
9.5 UMC SAFE ZONE CALIBRATION
Recently Updated Last updated: 12/28/2021
Safe Zone Calibration
This tells you how to set Safe Zone Offsets.
This procedures shows images that use both calibration assemblies.
 Important: The spindle probe must be calibrated before doing this procedure. This makes sure the accuracy of the probe to the machine position is correct. Refer to the Next Generation Control - Probe Calibration (VPS) procedure, in the diy.haascnc.com
Return the B and C axis to its home position.
Command the spindle probe into the spindle.
Press [EDIT] and navigate to the VPS tab. Press the [RIGHT ARROW] key and remove the center bore plug as prompted in the calibration set up.
Input the approximate diameter of the center bore, use calipers to double check.
This input  is to set the angle at which the probe will come out before moving down to touch the platter.
NOTE: This input is to avoid the probe incorrectly touching any of the platter plugs or missing the platter by going down in the T-slots instead.
This input is to set the distance at which the probe will come out before moving down to touch the platter.
 NOTE: This input works similar to the angle input as it is  to avoid the probe incorrectly touching any of the platter plugs or missing the platter by going down in the T-slots instead. Both inputs are needed to avoid plugs or T-slots.
The final step is to jog the probe into position for calibration. This will be in the center of the bore on the platter. The VPS will instruct you to also jog the probe 0.25 in above the plane of the platter.
Press [CYCLE START] to run the calibration or [F4] to output to MDI and review the code.
The Safe Zone program will populate the values that are found into the settings page using the code shown in the picture.
G167 provides the ability to write to settings, P code [1] is the setting number the program is writing to, Q code [2] is the value of the the Macro Variable the P code setting will be populated with, and the K code [3] essentially means it will keep these values in the setting once the program is over.
Verify settings 378-380 are populated.
