Spindle Liner Kit Reference Table - RD0068
Service Home Spindle Liner Kit Reference Table - RD0068
Recently Updated Last updated: 06/23/2026
RD0068
Revision D - 06/2026
Use the following document to select the correct spindle liner kit for your Haas Barfeeder.
NOTE:  This document was previously called AD0022.
Liner Kit 1.75
Lathe Model Adapter Kit Liner Kit
Install Kit
(Adapter & Liner Kit)
Liner Kit Contains (*)
Haas Tooling PN
93-1001170
(LINER KIT 1.8 PRECISION)
Fits Bar Diameter (inch) Haas Tooling PN
93-1001171
(LINER KIT 46 M PRECISION)
Fits Bar Diameter (mm)
ST-10/L/Y/LY
Note : ST-10 built before 2017 require coolant collector extension P/N : 25-2618
LINER ADAPTER 1.75
Haas Tooling P/N: 05-0207
Haas Tooling P/N: 08-2011
Haas Tooling P/N: 08-2012
93-1001170  BAR FEEDER INSTALL KIT 1.75" PRECISION
93-1001171  BAR FEEDER INSTALL KIT 46MM PRECISION
05-0617
05-0616
05-0615
05-0614
05-0613
05-0612
05-0611
05-0610
05-0609
05-0608
05-0607
LINER 3/8 X 1.8 X 48"
LINER 1/2 X 1.8 X 48"
LINER 5/8 X 1.8 X 48"
LINER 3/4 X 1.8 X 48"
LINER 7/8 X 1.8 X 48"
LINER 1 X 1.8 X 48"
LINER 1-1/8 X 1.8 X 48"
LINER 1-1/4 X 1.8 X 48"
LINER 1-3/8 X 1.8 X 48"
LINER 1-1/2 X 1.8 X 48"
LINER 1-5/8 X 1.8 X48"
3/8
1/2
5/8
3/4
7/8
1-1/4
1-3/8
1-1/2
1-5/8
05-0637
05-0636
05-0635
05-0634
05-0633
05-0632
05-0631
05-0630
05-0629
05-0628
05-0627
LINER 10 X 46 X 1220 MM
LINER 12 X 46 X 1220 MM
LINER 16 X 46 X 1220 MM
LINER 18 X 46 X 1220 MM
LINER 20 X 46 X 1220 MM
LINER 25 X 46 X 1220 MM
LINER 30 X 46 X 1220 MM
LINER 32 X 46 X 1220 MM
LINER 35 X 46 X 1220 MM
LINER 38 X 46 X 1220 MM
LINER 40 X 46 X 1220 MM
16
18
20
25
30
32
35
38
40
(*) All extruded liners listed are available individually. Use the listed part number to order.
Liner Kit 1.75 Extended Liner System
Install Kit
(Extended Liner System & Liner Kit)
Haas Tooling P/N
Liner Description (Standard)
Fits Bar Diameter (inch) Haas Tooling P/N
Liner Description (Metric)
(After 08/2023)
ST-10/L/Y/LY
N/A
N/A
93-1000844 -LINER SYS 46 X 1500 MM
93-1000845 -LINER SYS 1.8 X 60"0
05-0722
05-0723
05-0724
05-0726
05-0725
05-0727
05-0728
05-0729
05-0730
05-0732
05-0731
LINER 3/8 X 1.8 X 60"
LINER 1/2 X 1.8 X 60"
LINER 5/8 X 1.8 X 60"
LINER 3/4 X 1.8 X 60"
LINER 7/8 X 1.8 X 60"
LINER 1 X 1.8 X 60"
LINER 1-1/8 X 1.8 X 60"
LINER 1-1/4 X 1.8 X 60"
LINER 1-3/8 X 1.8 X 60"
LINER 1-1/2 X 1.8 X 60"
LINER 1-5/8 X 1.8 X60"
3/8
1/2
5/8
3/4
7/8
1-1/4
1-3/8
1-1/2
1-5/8
05-0711
05-0712
05-0713
05-0714
05-0715
05-0716
05-0717
05-0718
05-0719
05-0720
05-0721
LINER 10 X 46 X 1500 MM
LINER 12 X 46 X 1500MM
LINER 16 X 46 X 1500 MM
LINER 18 X 46 X 1500 MM
LINER 20 X 46 X 1500 MM
LINER 25 X 46 X 1500 MM
LINER 30 X 46 X 1500 MM
LINER 32 X 46 X 1500 MM
LINER 35 X 46 X 1500 MM
LINER 38 X 46 X 1500 MM
LINER 40 X 46 X 1500 MM
16
18
20
25
30
32
35
38
40
Liner Kit 2.00
Install Kit
Liner Kit Contains (*) Fits Bar Diameter (inch) Fits Bar Diameter (mm)
(Prior to 04/2019)
ST-20/SS/Y/SSY
DS-30/SS/Y/SSY
2.0" (51 mm) Thru Bore
Hydraulic union piston threads 54 mm
LINER ADAPTER 2.00
LINER1750-20 (***)
Haas Tooling P/N: 05-0197
 LINER KIT 1.8   PRECISION (**)
LINER KIT 46 M PRECISION (**)
N/A
LINER KIT 1.8 PRECISION(**)
LINER KIT 46 M PRECISION(**)
LINER1750-20 1-3/4 (45MM)(***)
3/8 - 1 5/8
1-3/4
10 - 40
45
(**) Must use a liner sleeve for smaller diameter liners. Refer to the installation instructions.
(***) Liner Sleeve
Liner Kit 2.50
Install Kit
93-1001183
(LINER KIT 2.5 PRECISION)
93-1001184
(LINER KIT 64 M PRECISION)
ST-15, ST-15Y (Prior to 10/2019)
Hydraulic union piston threads 84 mm
93-1000063 SPINDLE LINER ADAPTER 2.50 (84MM THDS)
Haas Tooling P/N: 08-2023
Haas Tooling P/N: 08-2024
N/A
08-2011 LINER KIT 1.8 PRECISION(**)
05-0606 LINER 1.75 X 2.5 X 48"
05-0605 LINER 2.00 X 2.5 X 48"​
05-0604 LINER 2.25 X 2.5 X 48"
      05-0734 LINER SLEEVE 1.80 X 2.5  X 48"(***)
3/8 - 1 5/8
1-3/4
08-2012 LINER KIT 46 M PRECISION(**)
05-0626 LINER 45 X 64 X 1220 MM​
05-0625 LINER 50 X 64 X 1220 MM​
05-0624 LINER 55 X 64 X 1220 MM
  10 - 40
45
50
55
ST-15/L/Y/LY(10/2019 to Present)
ST-20/L/Y/LY(04/2019 to Present)
DS-20Y
Hydraulic union piston threads 74 mm
LINER ADAPTER 2.50
Haas Tooling P/N: 05-0208
93-1001183  BAR FEEDER INSTALL KIT 2.5" PRECISION
93-1001184  BAR FEEDER INSTALL KIT 64MM PRECISION
(***) Liner Sleeve
Liner kit 3.00
Install Kit
Liner Kit Contains(*)
Haas Tooling PN
93-1001185
(LINER KIT 3.0 PRECISION)
93-1001186
(LINER KIT 76MM PRECISION)
(01/2018 to Present)
ST-25/L/Y/LY
ST-30/L/Y/LY
DS-25Y
DS-30Y
LINER ADAPTER 3.00
Haas Tooling P/N: 05-0206
93-1000065 SPINDLE LINER ADAPTER 3.00 (76MM THDS)
93-2848 LINER ADAPTER SERVICE KIT 3.0 (Pre-reboot with gearbox)
Haas Tooling P/N: 08-2019
Haas Tooling P/N: 08-2020
93-1001185  BAR FEEDER INSTALL KIT 3.0" PRECISION
93-1001186  BAR FEEDER INSTALL KIT 76MM PRECISION
08-2011
05-0603
05-0602
05-0601
05-0600
05-0599
05-0735
LINER KIT 1.8 INCH PRECISION (**)
LINER 1.75 X 3 X 48"
LINER 2 X 3 X 48"
LINER 2.25 X 3 X 48"
LINER 2.5 X 3 X 48"
LINER 2.75 X 3 X 48"
LINER SLEEVE 1.80 X 3.0 X 48" (***)
3/8 - 1 5/8
1-3/4
2-1/2
2-3/4
08-2012
05-0623
05-0622
05-0621
05-0620
05-0619
05-0735
LINER 45 X 76 X 1220 MM
LINER 50 X 76 X 1220 MM
LINER 55 X 76 X 1220 MM
LINER 60 X 76 X 1220 MM
LINER 70 X 76 X 1220 MM
10 - 40
45
50
55
60
70
(04/2014 - 01/2018)
ST-25/Y
ST-30/SS/Y/SSY
DS-30 with DS-3B
DS-30Y with DS-3B
DS-30SS with DS-3BSS
DS-30SSY with DS-3BSS
3.0" (76 mm)
(Before 04/2014)
ST-30
ST-30SS
ST-30SSY
DS-30 with DS-3B
DS-30Y with DS-3B
3.0" (76 mm)
LAGK300-89
N/A
(***)Liner Sleeve
LINER KIT 4.00
Lathe Model Adapter Kit Liner Kit Part Description Quantity
(Before 06/2020)
ST-35/L/Y/LY
4.0" (102 mm)
N/A LINER KIT 4.00
PVC Spacer
(****) Bar Guide Disk (Blank)
Compression Nut
Bar Guide Disk (1.0" I.D.)
Liner Adapter 0.25" - 3.125" Diameter
Liner Retainer Ring
Liner Insert 318 S30 BB
Liner Insert 300 S30 BB
22
(****) Order item UDK15 to receive 33 replacement bar guide disks.
All other parts listed are available only in kit LINER KIT 4.00; they are not available individually.
LINER KIT 4.00 12
(06/2020 to Present)
ST-28/L/Y/LY, ST-35/L/Y/LY
4.0" (102 mm)
N/A
LINER KIT 4.00 12
93-1000888 BAR FEEDER INST KIT, 4.0"; 12" CYL
Bar Feeder not compatible with Gearbox Equipped Lathes
PVC Spacer
Compression Nut
Liner Retainer Ring
22
All other parts listed are available only in kit LINER KIT 4.00 12; they are not available individually.
LINERKIT-4-ST40 / 93-1000635
(01/2021 to Present)
ST-40/Y/S/SY/L/LY
N/A
LINERKIT-4-ST40
93-1000635 LINER KIT ST-40 2021
PVC Spacer
Compression Nut
Liner Retainer Ring
22
All other parts listed are available only in kit LINERKIT-4-ST40; they are not available individually.
