DC-2 Drill Center
  1. Vertical Mills
  2. High-Speed Drill Centers
  3. DC-2 Drill Center
DC-2 Drill Center
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
High-Speed Drill Center with 39.4" x 19.7" x 13" travels, 30 taper
The DC-2 is a larger version of our traditional-style drill/tap machine that offers more X and Y travel and a larger table to accommodate bigger parts, multiple vises, or high-density setups. The machine is equipped with a 10,000-rpm BT30 spindle and high-speed turret-style tool changer to minimize cut-to-cut times and shorten cycle times. Choose the optional 15,000-rpm or 20,000-rpm spindle to cut production times even further.
The rear chip discharge of the DC-2 allows machines to be placed side-by-side to maximize floor space, and provides easy side access for automation systems. The machine’s one-piece, extra-wide base provides stable support for heavier parts and fixtures, and the wide-stance triangulated column increases overall rigidity.
  • More travel and larger table than DC-1
  • 10,000-rpm BT30 spindle
  • 15,000-rpm or 20,000-rpm available
  • Fast turret-style tool changer, 21 tools
  • Available auto window for easy automation
  • Rear chip discharge with front chip flush
See Available Stock
Current Lead Time
  • 30 Taper
  • 3 Axis
  • 10k RPM
  • 21 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
HAAS HIGH-SPEED DRILL CENTERS
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Machine Info
    • Rotary Fit chart
    Travels S.A.E METRIC
    X Axis 39.40 in 1000 mm
    Y Axis 19.70 in 500 mm
    Z Axis 13.00 in 330 mm
    Spindle Nose to Table (~ max) 18.9 in 480 mm
    Spindle Nose to Table (~ min) 5.9 in 150 mm
    Spindle S.A.E METRIC
    Max Rating 15.0 hp 11.2 kW
    Max Speed 10000 rpm 10000 rpm
    Max Torque 14.0 ft-lbf @ 2500 rpm 19.0 Nm @ 2500 rpm
    Taper BT30 BT30
    Bearing Lubrication Grease Packed Grease Packed
    Cooling Liquid Cooled Liquid Cooled
    Table S.A.E METRIC
    Length 43.3 in 1100 mm
    Width 19.7 in 500 mm
    T-Slot Width 0.630 in 16 mm
    T-Slot Center Distance 3.94 in 100 mm
    Number of Std T-Slots 5 5
    Max Weight on Table (evenly distributed) 772 lb 350 kg
    Feedrates S.A.E METRIC
    Max Cutting 1200 ipm 30.5 m/min
    Rapids on X 1890 ipm 48.0 m/min
    Rapids on Y 1890 ipm 48.0 m/min
    Rapids on Z 1890 ipm 48.0 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 2054 lbf 9137 N
    Max Thrust Y 2054 lbf 9137 N
    Max Thrust Z 2054 lbf 9137 N
    Tool Changer S.A.E METRIC
    Type Turret Turret
    Capacity 21 21
    Max Tool Diameter (full)** 2.4 in 60 mm
    Max Tool Diameter, Large (adjacent empty)** 3.1 in 80 mm
    Max Tool Length (from gage line) 7.90 in 200 mm
    Max Tool Weight 4.4 lb 2.0 kg
    Tool-to-Tool (avg) 1.50 s 1.50 s
    Chip-to-Chip (avg) 2.50 s 2.50 s
    Tapping S.A.E METRIC
    Max Tapping Speed 5000 rpm 5000 rpm
    General S.A.E METRIC
    Coolant Capacity 66 gal 250 L
    Inline Air Hose 3/8 in 3/8 in
    Coupler (Air) 3/8 in 3/8 in
    Spindle Speed 10000 rpm 10000 rpm
    Spindle Power 15.0 hp 11.2 kW
    Domestic Pallet 123.8 in x 90.0 in x 101.0 in 314 cm x 229 cm x 257 cm
    Export Pallet 123.8 in x 90.0 in x 101.0 in 314 cm x 229 cm x 257 cm
    Weight 8860 lb 4019.0 kg
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    AVAILABLE OPTIONS
    VIDEOS
    RELATED PRODUCTS
    Standard Features
    • 10,000-rpm Spindle, DC Series
    • 21-Tool Turret-Style Tool Changer
    • Window Air Blast
    • 66-Gallon (250 liter) Coolant Tank
    • Through-Spindle Coolant Ready
    • Multi-Stage Coolant Pump
    • Control Widescreen Monitor
    • Ethernet Interface
    • Power Surge Protection
    • Advanced Tool Management
    • Media Display M-Code; M130
    • Safe Run
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    • Convenience Package
    • Phone Charging Stand
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    • Installation Guide
    • Layout Drawing
    • Torque Chart
    • Operator’s Manual
    Videos
    TRADITIONAL FORMAT, PROVEN HAAS VALUE
    ✓  High-speed turret-style tool changer
    ✓  Rear chip discharge and coolant chip flush
    ✓  Automation ready – Cobot or APL
    ✓  User-friendly Haas control
    ✓  High-performance spindles
    ✓  Easy 4th- and 5th-axis integration
    VIEW DETAILS
    DOWNLOAD BROCHURE
    Haas Wireless Intuitive Probing System
    With the Haas Wireless Intuitive Probing System (WIPS), you can set tool and work offsets in a fraction of the time. No more edge finders or slips of paper under the tool needed.
    Display Pictures and Videos on Your Haas
    With M130, you can display setup sheets, tool lists, work instructions, and even videos – all within your program. No more taping work instructions to the machine, or hand writing notes telling your operator how to load or inspect a part; put it all in your NC program!
    Simplify 3+2 and 5-Axis Machining
    Using DWO/TCPC (Dynamic Work Offsets / Tool Center Point Control), you can create your CAM program ahead of time, and then place the workholding and part anywhere on the table, with no need to repost your program!
    RELATED PRODUCTS
    SMALLER VERSION
    Haas DC-1
    DC-1 Drill Center
    High-Speed Drill Center with 23.6" x 17.7" x 13" travels, 30 taper
    • 30 Taper
    • 3 Axis
    • 10k RPM
    • 21 Tool Capacity
        CNY ONLY
    Learn More Build & Price
    DIFFERENT APPROACH
    Haas DT-2
    DT-2
    CNC Drill/Tap Center with 28" x 16" x 15.5" travels
    • 30 Taper
    • 3 Axis
    • 10k RPM
    • 20+1 Tool Capacity
        CNY ONLY
    COMPACT 40-TAPER
    Haas Super Mini Mill
    Super Mini Mill
    Super-Speed Mini Vertical Mill with 16" x 14" x 15" travels
    • 40 Taper
    • 3 Axis
    • 10k RPM
    • 30+1 Tool Capacity
        CNY ONLY
    HA5C DC-2 POSITIVE FIT
    HA5C-T DC-2 POSITIVE FIT
    HA5CS DC-2 POSITIVE FIT
    T5C DC-2 POSITIVE FIT
    HRT100 DC-2 POSITIVE FIT
    HRT160 DC-2 POSITIVE FIT
    HRT160SP DC-2 POSITIVE FIT
    HRT160SS DC-2 POSITIVE FIT
    HRT210 DC-2 POSITIVE FIT
    HRT210HS DC-2 POSITIVE FIT
    HRT210HT DC-2 POSITIVE FIT
    HRT210SP DC-2 POSITIVE FIT
    HRT210SS DC-2 POSITIVE FIT
    HRTA5 DC-2 POSITIVE FIT
    HRTA6 DC-2 POSITIVE FIT
    TH240 DC-2 POSITIVE FIT
    TRT70 DC-2 POSITIVE FIT
    HA2TS DC-2 POSITIVE FIT
    T5C2 DC-2 POSITIVE FIT
    T5C3 DC-2 POSITIVE FIT
    T5C4 DC-2 POSITIVE FIT
    HA5C2 DC-2 POSITIVE FIT
    HA5C2-T DC-2 POSITIVE FIT
    HA5C3 DC-2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HA5C3-T DC-2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HA5C4 DC-2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HA5C4-T DC-2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HRT200HS DC-2 POSITIVE FIT
    HQDA5 DC-2 POSITIVE FIT
    HQDA6 DC-2 POSITIVE FIT
    HRT210S DC-2 POSITIVE FIT
    Build & Price
    Get Started
    Need More Information?
