VM-10
  1. Vertical Mills
  2. Mold Machines
  3. VM-10
VM-10
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
CNC Vertical Mold Machine with 120" x 32" x 30" travels
The Haas VM Series machines are high-performance VMCs that provide the accuracy, rigidity, and thermal stability required for mold making, tool & die work, and other high-precision industries. Each machine features a generous work cube, a multi-fixturing table, and a 12,000-rpm inline direct-drive spindle. Standard features include the Haas high-speed control with full look-ahead, a side-mount tool changer, a programmable coolant nozzle, an automatic air gun, and much more.
  • Inline direct-drive spindle
  • Side-mount tool changer
  • Multi-fixturing table
  • High-speed machining software
See Available Stock
Current Lead Time
  • 40 Taper
  • 3 Axis
  • 12k RPM
  • 30+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
VM SERIES
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Automation
    • Machine Info
    • Rotary Fit chart
    Travels S.A.E METRIC
    X Axis 120.00 in 3048 mm
    Y Axis 32.00 in 813 mm
    Z Axis 30.00 in 762 mm
    Spindle Nose to Table (~ max) 34.0 in 864 mm
    Spindle Nose to Table (~ min) 4.0 in 102 mm
    Spindle S.A.E METRIC
    Max Rating 30.0 hp 22.4 kW
    Max Speed 12000 rpm 12000 rpm
    Max Torque 90.0 ft-lbf @ 2000 rpm 122.0 Nm @ 2000 rpm
    Taper CT40 | BT40 | HSK-A63 CT40 | BT40 | HSK-A63
    Bearing Lubrication Air / Oil Injection Air / Oil Injection
    Cooling Coolant Jacket Coolant Jacket
    Table S.A.E METRIC
    Length 120.0 in 3048 mm
    Width 28.0 in 711 mm
    T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
    T-Slot Center Distance 4.92 in 125 mm
    Number of Std T-Slots 5 in X and 24 in Y 5 in X and 24 in Y
    Max Weight on Table (evenly distributed) 4000 lb 1814 kg
    Feedrates S.A.E METRIC
    Max Cutting 360 ipm 9.1 m/min
    Rapids on X 360 ipm 9.1 m/min
    Rapids on Y 600 ipm 15.2 m/min
    Rapids on Z 600 ipm 15.2 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 3400 lbf 15124 N
    Max Thrust Y 3400 lbf 15124 N
    Max Thrust Z 5600 lbf 24910 N
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 30+1 30+1
    Max Tool Diameter (full)** 2.5 in 64 mm
    Max Tool Diameter, Large (adjacent empty)** 5.0 in 127 mm
    Max Tool Diameter, Extra-Large (adjacent empty)** 6.0 in 152 mm
    Max Tool Length (from gage line) 16.00 in 406 mm
    Max Tool Weight 12.0 lb 5.4 kg
    Tool-to-Tool (avg) 2.80 s 2.80 s
    Chip-to-Chip (avg) 3.60 s 3.60 s
    General S.A.E METRIC
    Coolant Capacity 95 gal 360 L
    Inline Air Hose 3/8 in 3/8 in
    Coupler (Air) 3/8 in 3/8 in
    Spindle Speed 12000 rpm 12000 rpm
    Spindle Power 30.0 hp 22.4 kW
    Domestic Pallet 288.0 in x 102.0 in x 128.5 in 732 cm x 260 cm x 326 cm
    Export Crate 288.0 in x 105.0 in x 130.5 in 732 cm x 267 cm x 331 cm
    Weight 30100 lb 13654.0 kg
    Domestic Pallet w/EC Option 288 in x 102 in x 135 in 732 cm x 260 cm x 343 cm
    Export Crate w/EC Option 288 in x 105 in x 139 in 732 cm x 267 cm x 354 cm
    Weight w/EC Option 30100 lb 13654 kg
    Domestic Pallet w/50+1 SMTC 288 in x 102 in x 133 in 732 cm x 260 cm x 338 cm
    Export Crate w/50+1 SMTC 288 in x 105 in x 136 in 732 cm x 267 cm x 344 cm
    Weight w/50+1 SMTC 30100 lb 13654 kg
    Domestic Pallet w/EC Option & 50+1 SMTC 288 in x 102 in x 143 in 732 cm x 260 cm x 364 cm
    Export Crate w/EC Option & 50+1 SMTC 288 in x 105 in x 143 in 732 cm x 267 cm x 364 cm
    Weight w/EC Option & 50+1 SMTC 30100 lb 13654 kg
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    Standard Features
    • 12,000-rpm Spindle
    • 30+1 Side-Mount Tool Changer
    • Programmable Coolant Nozzle
    • Automatic Air Gun
    • Chip Auger
    • Window Air Blast
    • 95-Gallon Coolant Tank
    • Chip Tray Filter Kit
    • Multi-Stage Coolant Pump
    • Chip Washdown Feature
    • Control Widescreen Monitor
    • Large Remote Jog Handle with Touchscreen Display
    • Ethernet Interface
    • Power Surge Protection
    • Advanced Tool Management
    • Media Display M-Code; M130
    • Safe Run
    • HaasDrop
    • High-Speed Machining
    • Rigid Tapping
    • User-Definable Macros
    • Coordinate Rotation and Scaling
    • ECO Mode
    • Table Auxiliary Air Supply
    • Stainless Steel Way Covers
    • Phone Charging Stand
    Shipping
    • Lifting Provision
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    ANSWERS TO YOUR CONCERNS ABOUT ADDING A HAAS ROBOT: It won’t take up much space, cost a ton of money, or take weeks to integrate.
    SPACE EFFICIENT
    COST EFFECTIVE
    EASY TO INTEGRATE
    EASY TO LEARN
    AVAILABLE OPTIONS
    DOCUMENTS
    VIDEOS
    RELATED PRODUCTS
    Standard Features
    • Automatic Air Gun
    • Chip Auger
    • Window Air Blast
    • Safe Run
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    Shipping
    • Lifting Provision
    Warranty
    Available Options
    Automation Options
    DOCUMENTS
    • 3D Model (ZIP) (Coming Soon)
    • Installation Guide
    • Anchoring Template
    • Layout Drawing (Coming Soon)
    • Torque Chart
    • Operator’s Manual
    Videos
    Through-Tool Air Blast – TAB
    Haas TAB functions just like through-spindle coolant, except uses a high-pressure, high-volume blast of air. When you can’t use coolant, but need to clear those chips, check out TAB.
    Minimum Quantity Lubrication System
    Can’t use water-based coolant on your parts . . . but still need to keep your cutting tools lubricated? The Haas Minimum Quantity Lubrication System can help you out.
    Avoiding a Crash
    In this Haas Tip of the Day, Mark gives some pointers on using settings in the Haas control to keep from breaking your tool – or worse!
    How to Start A Job in the Middle of A Program
    Have you ever had your power go out right in the middle of your program? Or maybe you broke a tool, or needed to change an insert, or wanted to inspect your part during the finish pass. With Haas’ Program Restart, it’s no problem!
    RELATED PRODUCTS
    Standard Model
    Haas VF-1040
    VF-10/40
    CNC Vertical Mill with 120" x 32" x 30" travels
    • 40 Taper
    • 3 Axis
    • 8.1k RPM
        CNY ONLY
    Learn More Build & Price
    SMALLER WORK ENVELOPE
    Haas VM-9
    VM-9
    CNC Vertical Mold Machine with 84" x 40" x 30" travels
    • 40 Taper
    • 3 Axis
    • 12k RPM
        CNY ONLY
    HIGHER PRODUCTION
    Haas VF-10SS
    VF-10SS
    Super-Speed CNC Vertical Mill with 120" x 32" x 30" travels
    • 40 Taper
    • 3 Axis
    • 12k RPM
        CNY ONLY
    TH450 VM-10 POSITIVE FIT
    HA2TS VM-10 POSITIVE FIT
    HA5C VM-10 POSITIVE FIT
    HA5C2 VM-10 POSITIVE FIT
    HA5C3 VM-10 POSITIVE FIT
    HA5C4 VM-10 POSITIVE FIT
    HA5CS VM-10 POSITIVE FIT
    HRC160 VM-10 POSITIVE FIT
    HRC210 VM-10 POSITIVE FIT
    HRT160 VM-10 POSITIVE FIT
    HRT160-2 VM-10 POSITIVE FIT
    HRT160SP VM-10 POSITIVE FIT
    HRT160SS VM-10 POSITIVE FIT
    HRT210 VM-10 POSITIVE FIT
    HRT210-2 VM-10 POSITIVE FIT
    HRT210M VM-10 POSITIVE FIT
    HRT210SP VM-10 POSITIVE FIT
    HRT310 VM-10 POSITIVE FIT
    HRT310SP VM-10 POSITIVE FIT
    HRT450 VM-10 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HRTA5 VM-10 POSITIVE FIT
    HRTA6 VM-10 POSITIVE FIT
    T5C VM-10 POSITIVE FIT
    T5C2 VM-10 POSITIVE FIT
    T5C3 VM-10 POSITIVE FIT
    T5C4 VM-10 POSITIVE FIT
    TR160 VM-10 POSITIVE FIT
    TR160-2 VM-10 POSITIVE FIT
    TR200Y VM-10 POSITIVE FIT
    TR210 VM-10 POSITIVE FIT
    TR310 VM-10 POSITIVE FIT
    TRT100 VM-10 POSITIVE FIT
    TRT160 VM-10 POSITIVE FIT
    TRT210 VM-10 POSITIVE FIT
    TRT70 VM-10 POSITIVE FIT
    HRT210HT VM-10 POSITIVE FIT
    TH240 VM-10 POSITIVE FIT
    HRT210SS VM-10 POSITIVE FIT
    HA5C-T VM-10 POSITIVE FIT
    HA5C2-T VM-10 POSITIVE FIT
    HA5C3-T VM-10 POSITIVE FIT
    HA5C4-T VM-10 POSITIVE FIT
    TRT310 VM-10 POSITIVE FIT
    HRT310SS VM-10 POSITIVE FIT
    LT350 VM-10 POSITIVE FIT
    HRT210VM VM-10 POSITIVE FIT
    LT260 VM-10 POSITIVE FIT
    HRT200HS VM-10 POSITIVE FIT
    HQDA5 VM-10 POSITIVE FIT
    HQDA6 VM-10 POSITIVE FIT
    HRT210S VM-10 POSITIVE FIT
    HDD255 VM-10 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    Build & Price
    Get Started
    Need More Information?
