Mill Spindle C-Axis (MILL SPDL C-AXIS)
Product Image
GET QUOTE
Mill Spindle C-Axis Drive
    CNY ONLY
  • Mill, drill, and tap on multiple sides of a part
  • Fully programmable interpolated motion
  • Accurate positioning to nearly any angle
  • Mounts to the mill spindle
Our Mill Spindle C-Axis Drive allows you to accurately position right-angle milling heads to nearly any angle for milling, drilling, and tapping on multiple sides of a part.
This is a FULLY programmable axis that allows simultaneous motion interpolated with the X, Y, Z, and even A axes, making it possible to reach difficult internal features, or perform simple end work on longer parts – operations not possible with traditional 3- or 4-axis set ups.
NOTE: Requires a side-mount tool changer. Requires a Haas mill with 4th-axis drive and NGC software version 100.21.000.1130. Machines with a single-axis rotary installed will require both 4th- and 5th-axis drives. Not compatible with 2-axis rotaries.
WARNING! The size of the side-mount tool changer and the machine frame size may limit the diameter and weight of the angle-head tooling.
Currently available on new machines only. Not available for field installation.
DOWNLOAD BROCHURE
HAAS JOURNAL
    • Option Info
    • Specs
    DOCUMENTS
    AVAILABLE ON THESE MACHINES
    VIDEOS
    • Layout Drawing
    • C-Axis Stop Block 3D Model (Zip)
    SERVICE DOCUMENTS
    VIDEOS
    Add Accurate 360-Degree Positioning to Your Right Angle Head
    Do your VF Mill parts require difficult internal features and profiling? Haas' new Mill Spindle C-axis Drive Option gives you access to areas of your part you couldn't reach before. Mill, drill, and tap in confined internal spaces and hit any angle needed through 360 degrees of accurate rotation.
    SPECIFICATION S.A.E METRIC
    Max Speed 100 °/sec 100 °/sec
    Max Torque 145 ft-lbf 197 Nm
    Positioning Increment 0.001° .001°
    Gear Ratio 83:1 83:1
    Drive Type Worm Gear Worm Gear
    Need More Information?
