PCOOL - Installation - UMC-750 - AD0322
Service Home How To Procedures PCOOL - Installation - UMC-750 - AD0322
Recently Updated Last updated: 10/14/2025
AD0322
Applies to machines built from: May, 2011
- Jump to Section - 1. Introduction 2. Installation (5 steps) 3. Test (1 step) Back to Top
This procedure tells you how to install the Programmable Coolant Nozzle (PCOOL) on a UMC-750.
This document applies to:
  • 93-1000833 2021 PCOOL UMC750 PRE REBOOT
Use the UMC-750 Machine Version - Identification page to verify which UMC model you own.
The images show parts of the machine isolated. Do not remove parts unless the instructions tell you to.
Remove the upper spindle head covers.
Install these parts on the PCOOL ASSEMBLY [B] as shown in the image:
  1. SWIVEL FITTING [K]
  2. 45 DEGREE FITTING [L]
  3. P-COOL MILL DRILL HOSE [H]
  4. STRAIGHT FITTING [M]
Install the PCOOL ASSEMBLY [B] on the P­COOL MOUNT UMC-750 [A]. Use the (2) 1/4-20 X 1/2 SOCKET HEAD CAP SCREWS (SHCS) [E].
Install the hole PLUG [Q] onto the PCOOL MOUNT UMC-750 [A].
Remove the PCOOL mount cover from the UMC-750. Connect the PCOOL M12 CABLE [C] to the PCOOL and the junction box near the top of the spindle. Install the CABLE CLAMP [R]. Use the clamp and zip-ties to put the cable in the correct position. Put the remaining cable in a coil.
Install the PCOOL [1] to the spindle head cover [2]. Use the (4) 1/4-20 X 1/2 BHCS from the PCOOL mount cover.
 Note: Use the (2) 1/4"-20 X 1/2" BUTTON HEAD CAP SCREWS (BHCS) [F] in the kit to replace missing BHCS.
Install these parts on the PCOOL TUBE 1 [J] as shown:
  1. 90 DEGREE FITTING [N]
  2. STRAIGHT FITTING [O]
  3. FLOW BALL VALVE [P]
  4. STRAIGHT FITTING [O]
Put the tubes through the sheet metal bracket [1].
Use these parts to install the PCOOL TUBE 2 [I]:
  1. PIPE CLAMPS [S]
  2. 1/4 WASHER [G]
  3. SHCS 1/4-20 X 1 1/2 [D]
Connect the PCOOL TUBE 2 [I] onto the fittings [M] and [O].
Install the spindle head covers.
If your machine uses the Classic Haas Control:
Set the main circuit breaker to the ON position.
Press [POWER ON].
Press [EMERGENCY STOP].
Change Setting 7, PARAMETER LOCK to OFF.
Change Parameter 57:11 COOLANT SPIGOT to 1.
Release [EMERGENCY STOP].
If your machine uses the Next Generation Control:
Refer to Option - Activation Code + Patch - NGC for information on how to load these files on your control.
Test
Press [RESET] to clear each alarm.
Press [CLNT UP] and then [CLNT DOWN].
The PCOOL nozzle moves up and down.
For more information on how to position the spigot use the Programmable Coolant (PCOOL) - Spigot Positioning procedure.
