Tool Release Piston - Solenoid - Replacement - AD0335
Service Home How To Procedures Tool Release Piston - Solenoid - Replacement - AD0335
Recently Updated Last updated: 11/30/2018
AD0335
Applies to machines built from: January, 2013
- Jump to Section - 1. Solenoid Replacement 2. Mac Solenoid Configuration 3. Festo Solenoid Configuration 4. SMC Solenoid Configuration 5. Numatics Solenoid Configuration 6. Applicable Parts Back to Top
The service part P/N 93-11061; SOLENOID VALVE ASSY TRP HIGH FLOW is the replacement solenoid assembly for the TRP solenoid (does not include fittings).
These assemblies use solenoids from different manufacturers. The solenoid assemblies are different in appearance and configuration for machines made in different years. This can cause confusion when you replace this assembly.
Each of the solenoid assemblies have the same cable connectors. Use the fittings from the removed assembly to make the correct configuration for your machine. Refer to the images below:
 Note: For Some Numatics Assemblies, if clearance is necessary, use these parts from Haas or purchase them locally:
  • Haas P/N 58-3600, NIPPLE 3/8 NPT X 1 7/16 HEX BRASS
  • Haas P/N 58-3625, FITG REDUCER NPT1/2M NPT3/8F BRASS
 Note: For 50-Taper TRP Solenoid Assemblies, the output hose is connected to a barbed fitting. To install the hose on the new solenoid, use hose clamp P/N 59-4008 HOSE CLAMP 3/8-7/8 STD.
  1. 58-3625 FITTING, REDUCER NPT1/2M NPT3/8F BRASS
  2. 58-3600 NIPPLE, 3/8 NPT HEX BRASS
  3. 58-1722 FITTING, NPT3/8M NPT3/8F 90 BRASS
  4. 58-1381 MUFFLER FREE FLOW 3/8 NPTM
  5. 58-0915 FITG POLY1/2F NPT3/8M STR BRASS
  1. Plug is included with solenoid.
  2. 58-1574 FITTING POLY1/2F NPT1/4M STR BRASS
  3. 58-3069 AIR MUFFLER NPT1/4M EXTENDED BRASS
  4. 58-16751 FITTING, REDUCER NPT-1/2-M X NPT-1/4-F
  5. 58-0742 NIPPLE 1/4 NPT X 3 BRASS
  6. 58-1861 FITTING, MUFFLER NPT 1/4M FREE FLOW
  1. 58-1722 FITTING, NPT3/8M NPT3/8F 90 BRASS
  2. 58-1381 MUFFLER FREE FLOW 3/8 NPTM
  3. 58-3600 NIPPLE, 3/8 NPT HEX BRASS
  4. 58-3625 FITTING, REDUCER NPT1/2M NPT3/8F BRASS
  1. 58-3600 NIPPLE, 3/8 NPT HEX BRASS
  2. 58-3625 FITTING, REDUCER NPT1/2M NPT3/8F BRASS
Applicable Parts
KIT    93-11061    SOLENOID, VALVE 2W/2P M-CONNECTOR 18" TRP
