Broken Tool Detection - Raspberry Pi - Replacement - AD0942
Service Home How To Procedures Broken Tool Detection - Raspberry Pi - Replacement - AD0942
Recently Updated Last updated: 04/06/2026
AD0942
Revision A - 03/2026
This procedure will show how to replace the Raspberry Pi PCB of the Broken Tool Detection system inside the machine's control cabinet.
This procedure should apply to the follow service kits:
  • 93-5722: SERVICE BTD RASPBERRY ASSY
Note: This service kit is for machines with the 19" monitor. The minimum required software version for this is 100.25.001.1300.
Replacing Raspberry Pi
 Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
 Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
Remove the all the cables from the iPFDM board and remove it from the cabinet to gain access to the Maincon board
Remove the all the cables from the Raspberry Pi board or A62 board that needs to be replaced.
Remove the defective Raspberry Pi board or A62 board from Maincon enclosure.
Install the Raspberry Pi board [1] that came in the kit onto the Maincon enclosure using the provide PPHS 2-32 x 1/4 screws[2] .
Connect the BTD camera cable 79-0159 into the USB adapter 74-2003 [1] that connects into J6, the USB port, on the Raspberry Pi PCB.
 IMPORTANT: Make sure to insert the camera cable into the lower USB port.
Connect both LED lights to the +12V LED power cable 33-1228 [2] that goes into J3 on the Raspberry Pi PCB.
Connect the iPFDM/12VDC cable 33-1227A [3] from J1 on the Raspberry Pi PCB to J7 on the iPFDM board.
Connect the communication cable 79-0206 [4] from J8, the USB-C port, on the Raspberry Pi PCB to the USB port J8 on the MAINCON.
IMPORTANT: Make sure to insert the communication cable into the lower USB port.
