Cambox Servo Motor - Replacement
Service Home How To Procedures Cambox Servo Motor - Replacement
7.4 Cambox Servo Motor - Replacement
Recently Updated Last updated: 08/21/2025
Revision A 08/2025
This procedure covers changing an inline-mounted (not belted) cambox servo motor.
Replacement
Power OFF the machine
Remove necessary sheetmetal (in green). This will vary from machine to machine.
Unplug the cables [4]. Loosen coupling [2] and servo motor bolts [1]. Remove faulty servo motor.
When installing the motor, the fasteners must be tightened in stages to verify it is not binding from misalignment.
Install the motor and leave the motor mount [3], coupler [2], and servo motor [1] bolts finger tight. Slide the coupler up and down on the motor and worm drive shafts to verify there are no binds.
Torque the motor mount [3] and servo motor bolts [1]. Verify again that the coupler slides freely on the motor and worm drive shafts. Only then should you torque the coupler bolts [2].
HAAS TORQUE CHART
When reconnecting the servo motor cables, check that there is dielectric grease on the contact points of the cables.
IMPORTANT: Make sure to only place grease on on the contact points of the connectors. Do not apply excess grease to the entire face of the connector. This can cause damage to the servo motor.
Perform the Servo-Driven SMTC - Double Arm Grid Offset and Tool Changer Offset - NGC procedure.
