Coolant Sanitizer - Installation - AD0770
Service Home How To Procedures Coolant Sanitizer - Installation - AD0770
21.2 Coolant Sanitizer - Installation
Recently Updated Last updated: 10/24/2025
AD0770
This procedure will show how to install a Coolant Sanitizer.
Note: The Coolant Sanitizer option is compatible with all machines EXCEPT CM, CL and DESKTOP Machines.
  • 93-1001080 COOLANT SANITIZER FIELD INSTALL
Attach the Coolant Sanitizer [1] onto sheet metal above the coolant tank using the integrated magnets.
Note: The location of the Coolant Sanitizer will vary between machine series.
Connect the pump's power cable [1] to the Coolant Sanitzer's plug [2].
Note : There is an extra outlet integrated into the wiring system [2] for other 120V devices.
Connect the ozone tube [3] from the Coolant Sanitizer to the pump [4].
Place the pump at the bottom of the coolant tank near the chip tray using the installed magnets.
Important : Make sure that the ozone tube fitting [2] is facing up and that the ozone dispersing pipe [1] is facing away from the coolant pumps with the holes facing the sides.
(Optional) Route the power plug [1]  into the control cabinet and plug it into one of the outlets [2].
Important : The Coolant Sanitizer is a 110-120 V system so we reccomend using the electrical cabinet as a power source if the standard power grid in your area provides a different voltage.
ST-10/15 Installation
Install the pump assembly into the integrated coolant tank after connecting the power and the clear ozone tube.
Note : This illustration shows only one standard coolant pump installed but if your machine is equipt with a secondary high pressure coolant pump it would need to be temporarily removed during this install for ease of access.
The pump assembly [1]  should be facing the spindle side of the machine with the holes facing the side and roughly aligned with the cut out in the base casting.
Note : Installing the pump without any disassembly is the recommended method due to the limited access once it is in position.
Verification
Turn the Coolant sanitizer on using the power on button [1].
Verify that the coolant is flowing out of the pump.
The “Pump On” Light [2] should light up when pump/ozone is in use.
Squeeze the ozone tube [3] shut by hand to check that the ozone generator is functioning properly. Slight pressure should be felt when tube is shut closed.
If the coolant is discolored, the pump should improve it after a few minutes.
