Coolant VFD - Replacement - AD0516
Service Home How To Procedures Coolant VFD - Replacement - AD0516
20.2 Coolant VFD - Replacement
Recently Updated Last updated: 03/08/2023
AD0516
This procedure will explain how to replace the VFD.
The following procedure applies to:
  • 93-3501 SERVICE KIT FOR CLNT VFD
For machines built before 2/9/2022 with VFD 69-0025. The machine must be upgraded with the following kits depending on the number of VFDs installed.
  • 93-3499 - SINGLE VFD RETROFIT KIT
  • 93-3498 - DUAL VFD RETROFIT KIT
Important: Do not use VFD Adapter PCB 34-3031A on machines with I/O PCB boards 34-3490C as the VFD adapter is built into this board version.
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Removal
Remove the screws [1] holding VFD [2].
NOTE:  The SCHNEIDER brand is being shown on the illustration.
SCHNEIDER
Install the VFD the same way as the previous unit.
DELTA
Use the provided screws [1] to install the DELTA brand VFD where the previous VFD was placed.
DELTA brand VFD wiring
When installing a DELTA brand VFD it should be wired as shown:
  • DCM - Black Wire Jumper
  • MI1 and MI3 - Red Wire and Red jumper wire.
  • ACM - Black Wire
  • AVI - Brown Wire
  • RA - Orange Wire
  • RC - Green
SCHNEIDER brand VFD wiring
When installing a SCHNEIDER brand VFD it should be wired as shown:
  • [LI1] - Red Wire
 NOTE: The Red jumper wire does not get connected, install electrical tape to the end.
  • [COM] and [COM] - Black Wire and Black jumper wire.
  • [AI1] - Brown Wire
  • [RIA] - Orange Wire
  • [R1C] - Green
