DT/DM Rocker Arm - Replacement - AD0539
Service Home How To Procedures DT/DM Rocker Arm - Replacement - AD0539
6.3 DT/DM - Rocker Arm - Replacement
Recently Updated Last updated: 02/11/2025
AD0539
This procedure will explain how to replace the old style rocker arm [1] to the new style rocker arm [2].
  • 93-3296 ROCKER ARM ASSY 30T DT SERVICE
  • 93-3297 ROCKER ARM ASSY 40T DM SERVICE
Removal
Jog the Z Axis to the bottom of travel.
Press [EMERGENCY STOP].
Remove the rocker arm assembly. Follow these steps:
  • Remove the C-clip [5] from the clevis pin [6]. Push the clevis pin to remove it.
  • Disconnect the spring [4] from the striker block.
  • Loosen the (4) screws [1] from the inside bearing block [2].
  • Loosen the (4) screws [7] from the outside bearing block [8].
  • Remove the rocker arm assembly from the machine.
  • Do not remove the bottom half [3] of the inside bearing block.
  • Remove the dowel pins from the bearing blocks.
 Note: The illustration does not show the spindle and spindle motor.
Install the rocker arm with one bolt threaded loosely on each side [1].
Install the dowel pins into place with a 1/4-20 bolt to help screw in the dowl pins [2].
Install the remaining bolts and torque to the specified values
Install the clevis pin [2] to the TRP assembly and rocker arm assembly.
Install the c-clips [1] on both ends of the pin.
Attach the spring to the bolt highlighted in the image.
 NOTE: This will only apply if you have the new style spindle head without the striker block. If you have a striker block installed refer to the next step.
Attach the spring to the bolt connected to the striker block as shown in the image.
Please refer to the DT/DM Tool Changer Alignment Procedure to complete the Rocker arm replacement.
