E-Vise Screw - 5 inch - Replacement - AD0596
Service Home How To Procedures E-Vise Screw - 5 inch - Replacement - AD0596
4.4 E-Vise 5in Screw - Replacement
Recently Updated Last updated: 04/18/2022
AD0596
This product has been discontinued, documentation is for reference only.
This procedure outlines how to replace the screw and nuts on the 5 inch E-Vise.
This procedure applies to the following kit:
  • 93-3434: E-VISE 5 INCH SCREW SERVICE KIT
Removal
Remove the bolts [1] from the jaws.
Pry off the vise jaws [2].
Remove the pins notated as [1]. Save these as they will be reused later.
Remove the bolts [2] from the middle bracket.
Slide the screw and nut assembly out of the vise.
Unscrew the nuts [1] off of the screw.
Take off the bolts and remove the center bracket [2].
Note: Keep the center block assembly as it will be reused later.
Replacement
Remove the nuts [1] from the new screw.
Add molybdenum grease to the center [2] of the new screw.
 Note: Use the molybdenum grease that came with the e-vise.
Attach the center block assembly to the new screw as shown.
Reattach the left nut [1] to the new screw on the hexed side.
Reattach the right nut [2] to the otherside of the new screw.
Slide the new screw and nut assembly on the vise in the direction shown.
Screw in the bolts for the center bracket assembly [1].
Reinsert the pins [2] as shown.
Line the jaws [3] up with the pins and screw in the bolts [4] to secure the jaws.
Verification
Press [CURRENT COMMANDS] and navigate to the E-Vise under Devices > Workholding.
Press [F2] to clamp/unclamp the vise to make sure the vise actuates correctly.
