Haas Robot Package - Battery Replacement
Service Home How To Procedures Haas Robot Package - Battery Replacement
Recently Updated Last updated: 01/25/2022
Rev A - 10/2025
This procedure outlines how to replace the batteries in the robot arm or robot controller.
Recommendations:
  • Batteries should be changed once a year
  • When changing the batteries, hit E-Stop on the Haas control to prevent unexpected robot motion
Note: DO NOT turn off the robot or the Haas machine when changing the batteries.
Tools Required:
  • Flathead screwdriver
  • 3.00 mm allen key
  • 4 high-quality C batteries, industrial batteries are recommended.
HRP-1 Arm Battery Replacement
DO NOT turn off the machine or robot.
Hit the E-Stop on the Haas control to prevent unexpected robot motion.
Use a 3 mm allen key to remove the hardware from the battery shield and take off the battery shield and gasket.
Note: The battery shield may need to be pryed off using a flathead screwdriver.
Remove the compartment cover using a flathead screwdriver. Replace the batteries. Take note of the direction each battery is before removing the old batteries.
Put the compartment cover and battery shield back on, make sure the battery cover is secure tightly.
HRP-1 Control Battery Replacement
Follow the link below to replace the HRP-1 Control Battery[1].
Warning: Note that keeping the control unit unconnected to a battery for a long period of time may result in the memory contents being lost. Take a MD Backup copy of the robot programs and system variables before replacing the battery.
HRP-2/3 Control Battery Replacement
Follow the link below to replace the HRP-2/3 Control Battery[1].
