HRP-1 - Dual Gripper - Installation - AD0862
Service Home How To Procedures HRP-1 - Dual Gripper - Installation - AD0862
Recently Updated Last updated: 03/26/2025
AD0862
- Jump to Section - 1. Introduction 2. Gripper Installation (6 steps) 3. Verification Back to Top
This procedure tells you how to install the grippers for a Haas Robot Package 1.
This procedure applies to the following service kits:
  • 93-1000461: HRP-1 DUAL GRIPPER KIT
  • 93-1001207: HRP-1/HC10 DUAL GRIPPER KIT
 NOTE: The HRP-1/HC-10 Dual Gripper is backward compatible with any HRP-1.
There are two versions of the dual-action grippers for this section, both of which have the same installation process.
The location hole should be centered on top.
If you have the dual action gripper, install it to the end of the robot arm by removing the gripper adapter[1] from the gripper assembly.
Mount the adapter to the end of the robot arm.
Mount the gripper assembly to the gripper adapter with gripper 1 on the left. Gripper 1 should be have orange and purple zip ties[2] on the fittings.
If you have the single action gripper, install it to the end of the robot arm by removing the gripper adapter plate[1] from the gripper assembly.
Mount the adapter plate[1] to the end of the robot arm with the large pockets on the top and bottom.
Mount the gripper assembly to the gripper adapter plate.
Mount the angle adapter bracket to the end of the robot arm.
Mount the gripper assembly to the gripper angle adapter plate.
To install the bar gripper fingers, remove the slug gripper plates from the gripper bodies.
Install the Bar Gripper Bolt Plates[3] using the following hardware: 8 x SHCS M6[4]
  • Torque to 10 ft-lbs.
Install the Bar Gripper Fingers[2] using the following hardware: 8 x SHCS 1/4-20[1]
  • Torque to 13 ft-lbs.
Install the gripper fittings to the robot arm.
Purple → 2A    (Open gripper 1)
Orange → 2B    (Close gripper 1)
Grey → 1A    (Open gripper 2)
Blue → 1B    (Close gripper 2)
Route the air lines between the robot arm and gripper connecting to the same color coded fittings.
Install conduit to each pair of air lines.
 Note: Turn on the machine air by turning the valve in the CALM cabinet.
Verification
Test the operation of the grippers:
  • Verify that both grippers clamp and unclamp correctly.
  • Press the [CURRENT COMMANDS]  and go to Devices > Robot > Jogging tab.
  • Press [F2] to clamp/unclamp the Finish Gripper.
  • Press [F3] to clamp/unclamp the Raw Gripper.
