Hydraulic Power Unit - Hoses and Fittings - Maintenance
Service Home How To Procedures Hydraulic Power Unit - Hoses and Fittings - Maintenance
Recently Updated Last updated: 09/19/2018
- Jump to Section - 1. Hydraulic Power Unit - Hoses and Fittings - Maintenance (1 step) Back to Top
This procedures tells you how to examine hoses and fittings on a hydraulic power unit (HPU) for damage. The illustrations show the hydraulic hoses for the chuck. The instructions are the same for the other hydraulic hoses.
Push [POWER OFF]. Before you perform maintenance on the HPU, wait until no pressure [1] is in the HPU.
Replace the hose if it has cracks, bumps, wear, or a leak. Look for leaks at the HPU and at the chuck.
At the leak, tighten the female fitting [3] nut with your hand. Do not over tighten the fittings or you will crack the internal flare [4]. Hold the male fitting [2] with a wrench while you turn the female fitting [3] clockwise 1/8 of a turn with another wrench.
Test for leaks:
Push [POWER ON].
Operate the hydraulic function many times to see if the leakage continues. For example, open and close the chucks many times.
If the leakage continues, push [POWER OFF] to release the pressure [1] from the HPU.
Disconnect the hose. If the internal flare has a crack [4], replace the hose.
Replace the hose:
Connect the new hose at each end. Use your hand to tighten the female fitting [3]. Hold the male fitting [2] with a wrench while you turn the female fitting [3] clockwise 1/8 of a turn with another wrench. Test for leaks again. Use cable ties to move the hoses away from all edges.
