M-FININ - Option - Installation - AD0549
Service Home How To Procedures M-FININ - Option - Installation - AD0549
Recently Updated Last updated: 05/04/2021
AD0549
- Jump to Section - 1. Introduction 2. Installation 3. Operation 4. References Back to Top
This optional cable assembly from the I/O board of the Haas machine to a connector on the side of the control cabinet provides M-code/MFIN capability for controlling external devices. Allows an M-code to pause a CNC program, send a start signal to the device, and then resume the program when an MFIN (finished) signal is received from the device.
Once installed an accessory with a 4-pin male Amphenol 703-91-T-3300-1 screwlocking plug (Haas P/N 74-1510) can be controlled by the CNC machine.
This Document Applies to the following Kits:
  • 93-APC-READY AUTOMATIC PALLET CHANGER READY
  • 93-1000274    AUTOMATIC PALLET CHANGER READY
  • 93-1000651    AUTOMATIC PALLET CHANGER READY
  • 93-2395    AUTOMATIC PALLET CHANGER READY, NGC
  • 93-2396    CABLE ASSY FOR MCODE/MFIN CAPA, NGC
  • 93-1000307    M-CODE/MFIN CABLE ASSEMBLY
  • 93-MFININ    CABLE ASSEMBLY FOR MCODE/MFIN CAPA
Turn off power to the machine and open the control cabinet door.
Remove the plug from the side of the control cabinet.
Install the M-FIN connector in the side of the control cabinet. To do so, remove the nut from the plug, insert the wires [1] through the holes from the outside of the control cabinet.
Thread the wires through the nut and tighten the nut [2] against the control cabinet.
Connect the two wires. One pair of wires has a plug on it which is installed to P8 on the NGC I/O PCB.
Note: For Classic Haas Machine connect the plug to P10 on the I/O PCB.
The second pair of wires is made up of a red and black wire. These two wires are installed differently depending on machine options.
If the machine Does Not have an M-Code relay board the wires are connected to the M21 relay on the I/O PCB. Connect the red wire to the M21 N/O (normally open) terminal and the black wire to the M21 COM (common) terminal.
If the machine Does have an M-Code relay board the wires are connected to the M21 relay on the M-Code Relay Board. Connect the red wire to the N/O (normally open) terminal and the black wire to the COM (common) terminal.
Operation
Accessories are connected to the CNC control through the M-Fin plug. The accessories are then commanded using the M-Codes.
M-FIN Plug Diagram
  1. Signal (MFIN Input)
    Important: Use a relay to activate this input. Do not apply voltage to this input. When a M-Fin signal is sensed the diagnostic #18 M_FIN_INPUT bit will toggle.
  2. Ground
  3. Normally Open (N/O)
  4. Common (COM)
References
8M Option - Installation - AD0162
Robot Integration Aid - NGC
