Mini Conveyor - Motor Replacement - AD0731
Service Home How To Procedures Mini Conveyor - Motor Replacement - AD0731
19.4 Mini Conveyor - Motor Replacement
Recently Updated Last updated: 11/10/2023
AD0731
The Mini-Conveyor has been discontinued. This procedure is provided for reference purposes only and may not reflect current product availability or support
You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
Only authorized personnel with the proper training and certification should do this repair procedure.
All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
This procedure tells you how to install and wire a replacement motor for a mini conveyor. The motor should already be installed in the Mini Conveyor but in the event where the motor needs to be replaced or the Mini Coveyor Kit did not come with the motor installed, follow this procedure.
Motor Replacement
Push [E-STOP].
Disconnect Mini Conveyor from the power plug located inside the control cabinet.
Remove the Mini Conveyor from the Coolant Tank.
Remove the (4) screws [1] to remove the motor and the motor cover.
Disconnect Black and White [1] wires by loosening the screws to remove the motor and replace it with the motor provided in the kit.
Reconnect wires in the same order that the wires were connected.
Install motor and cover and screw the (4) bolts [1].
Place Mini Conveyor onto the Coolant Tank.
Connect Mini Conveyor to the power plug located inside the control cabinet.
