Machine Data Backup - NGC
Service Home How To Procedures Machine Data Backup - NGC
6.1 Machine Data Backup
Recently Updated Last updated: 04/28/2025
Applies to machines built from: September, 2015
Back Up Machine
Use this procedure to backup all of the machine files on your Next Generation Control machine.
Set Setting 155, Load Pocket Tables, to ON.
 Note: Make sure the memory lock key switch is in the unlocked position.
Push [LIST PROGRAM].
Use the cursor arrows to select the USB tab [1].
Push [F4], System [2].
Use the up and down cursor to select Back Up Machine [3].
Push [ENTER].
Important Information
  • The next step puts the copies of the machine data files in the open directory on the USB memory device.
  • The backup makes a .zip file. You can open this .zip file on the control or on a PC.
  • The name of the .zip file that contains the backup data has this structure: "HaasBackup", then the date. For example, HaasBackup(xx-xx-xxxx).zip.
  • You cannot make a backup file if the control is in MEMORY or USER DATA modes.
This screen lets you select the data files to make copies of.
 Caution: If the machine has software version 100.15.000.1011, DO NOT select User Data [2] when you make a backup. Go to the User Data tab [1]. Select the User Data files to backup. Push [F2] to copy the files to the USB memory device.
Use the up and down cursors to make a selection.
Push [ENTER] to select or deselect what you must backup.
Push [F4] to make the backup.
Know this information about the stored data.
  • System Data makes copies of these data files:
    • settings
    • offsets
    • macro variables
    • advanced tool management (ATM)
    • alarm history
    • key history
    • linear screw compensation (LSC)
    • network configurations
  • User Data makes copies of all the files in the User Data folder.
  • Programs makes copies of all the files in the Memory folder.
  • The approximate size of each selection shows on the right side of the display. The total Estimated size shows at the bottom.
  • If a selection is too large for the USB memory device, it is grey.
