P-COOL - Installation - UMC Series NGC - AD0588
Service Home How To Procedures P-COOL - Installation - UMC Series NGC - AD0588
5.5 P-COOL - Field Installation - UMC
Recently Updated Last updated: 02/28/2022
P-COOL - Installation - UMC-Series-NGC
AD0588
This procedure tells you how to install the Programmable Coolant Nozzle (PCOOL) on a UMC Series.
This document applies to:
  • 93-1000969 - PCOOL KIT UMC-500/750 REBOOT/1000/GM-2
  • 93-1000968 - PCOOL KIT UMC-750 PRE REBOOT 2023 (for pre reboot UCM-750)
Use the UMC-750 Machine Version - Identification page to verify which UMC model you own.
  You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
   Only authorized personnel with the proper training and certification should do this repair procedure.
   All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
The images show parts of the machine isolated. Do not remove parts unless the instructions tell you to.
Remove the upper spindle head covers.
Remove the Junction Box Z Cover
Remove the two plugs from the Spindle Mount Casting
Route the PCool cable (32-0356) through the head casting to the Junction Box labeled PROG. COOLANT
  • Install the coolant tube [1] to the casting with the 90 degree elbow fitting [2],
  • Loosen the lock nut [3] and rotate the P-Cool nozzle to the correct position [4].
  • Install the coolant tube with the fittings from the casting to the P-COOL unit.
  • Tighten all fittings so the P-COOL assembly does not leak.
IMPORTANT: LOOSEN UP THE TWO MOUNTING BOLTS TO ALLEVIATE STRESS ON THE SYSTEM, ONCE STRESS IS ALLEVIATED RE-TIGHTEN THE MOUNTING BOLTS.
  • Install P-COOL ASSY to the P-COOL sheet metal bracket.
  • Install the P-COOL unit to the casting.
NOTE: Be sure to route the cable through the cutout in the sheet metal bracket and up to the junction bracket.
Verify P-Cool Spigot is Enabled
  • Go into Service Mode
  • Navigate to the Factory Parameters page
  • Verify parameter 57.11 is set to TRUE
  • If it is FALSE, set the setting to TRUE
Test
Press [RESET] to clear each alarm.
Power cycle the machine and verify that the P-COOL homes and resets its count switch position.
Press [CLNT UP] and then [CLNT DOWN].
The PCOOL nozzle moves up and down.
For more information on how to position the spigot use the Programmable Coolant (PCOOL) - Spigot Positioning procedure.
