Pallet Pool - Central Lift Assembly - Replacement
Service Home How To Procedures Pallet Pool Central Lift Assembly - Replacement
Recently Updated Last updated: 02/23/2021
5.1 Pallet Pool Central Lift - Replacement
Pallet Pool - Lift/Rotate Cylinder Assembly - Removal
Remove the pallet pool enclosure panels [1], [2] and [3].
Rotate the PR axis to gain access to the front of the PS axis ballscrew.
Remove the bolts from the front [1] and the back [2] of the PS ballscrew cover [3].
Remove the PS ballscrew cover.
Rotate the PS axis to gain access to the slots [1] on the bottom of the PS saddle.
Jog the PS axis to align the PS ballnut housing mounting bolts with the slots [1].
Use an extention with the  SAE 5/16 hex bit to reach through the slots [1] and remove four bolts that fasten the PS ballnut housing to the underside of the PS ram.
Remove eight bolts [1].
Remove the ram cover [2].
Renove the lifting eye bolt [3] along with it's mounting hardware.
NOTE: Use the hforklift or other lifting device to lift the ram assembly [1] during this step.
Support the weight of the ram [1] with the lifting device.
Remove the sixteen bolts that secure tha ram to the PS linear guide trucks.
Remove the ram assembly.
Remove the cover plate [1].
Disconnect the cables [2] from PS axis servo motor and the home sensor.
Pull the cables [2] down through the center lift/rotate cylinder assembly.
Loose the four bolts that secure the PR axis gearbox [2] to the Pallet Pool base and slide the gearbox away from the PR drive gear.
Remove the center lift UP sensor [3].
Remove the center lift DOWN sensor [4].
Remove the PR axis home sensor [5] and the mounting bracket [6].
Remove the PR axis home sensor trip flag [7].
Disconnect the hydraulic lines from the center lift cylinder and remove the fittings [8].
Remove the six bolts [1] that secure the PR drive gear [2] to the bottom of the center lift/rotate cylinder [3]
 NOTE: Use the forklift or other lifting device to lift the saddle assembly [1] during this step.
Remove the six bolts [2] that secure the PS saddle to the center lift/rotate cylinder [3].
Remove the saddle.
Remove two bolts [1] and remove the PR axis hard stop [2].
Remove the remaining six bots [3] that secure the center lift cylinder.
Install two 1-1/2X13 eye bolts [1] into the pallet pool saddle mounting holes.
Use the hoist or the forklift and pull the center lift cylinder assembly [2] out of teh pallet pool base.
Pallet Pool - Lift/Rotate Cylinder Assembly - Conclusion
Verify Pallet Pool loading shelf alignment. Change parameters 15.078 PR AXIS TOOL CHANGE OFFSET and 16.078 PS AXIS TOOLCHANGE OFFSET if needed.
