Reverse Rotary Direction Setup - NGC
Service Home How To Procedures Reverse Rotary Direction Setup - NGC
11.3 Reverse Rotary Direction Setup
Recently Updated Last updated: 11/09/2022
Revision B - 05/2026
This procedure tells you how to load rotary files to reverse the rotary direction of your Haas rotary. The files supplied only apply to available Haas rotaries.
This procedure applies only to Haas rotaries on machines with software version 100.16.000.1030 and higher.
Note: Software version 100.21.000.1130 and later will not come with reverse rotary files.
This procedure will work for previous software versions that did not come with the desired reverse rotary file. Verify that your software is compatible with the rotary you wish to install. See Rotary - Compatibility and Servo Motor Configuration Identification for more information about rotary compatibility.
Updated
Download and extract the reverse rotary direction files.
Note: The complete reverse rotary folder must be loaded. Do not load an individual reverse rotary file from within the folder, as the procedure will not complete correctly.
Download Rev_User_Rot.zip
Find your rotary model in the extracted folder and copy it to a USB memory device.
Insert the USB memory device with the rotary configuration file into the USB port on the control pendant.
Press [LIST PROGRAM] and navigate to the USB tab [1].
Select your reverse rotary file [2]. Press [ENTER].
Note: The reverse rotary files that are loaded with this procedure will have an R in the Name column. These files will have the same name in the Model column as normal rotary files. Reverse files preloaded with the software will end with -R in the Model column.
Press [F2] to copy the reverse rotary file.
Navigate to User Data [3] on the Copy To screen.
Press the [RIGHT] CURSOR arrow to enter the User Data directory.
Navigate to the My Rotary directory.
Press the [RIGHT] CURSOR arrow to enter the My Rotary directory [1].
Press [ENTER] [2] to copy the rotary configuration file to this location.
Press [SETTING].
Navigate to the Rotary tab [1].
Type the model of your rotary and press [F1] to search. This example uses TRT210-P20 [2]. Reverse rotary files have the letter “R” in the Name column. Normal rotary files will be blank in the Name column.
Your reverse rotary file [3] is in the Select New Rotaries page.
Highlight the rotary files you want to activate and press [ENTER] to pull up the Select Table Orientation screen.
In the Select Table Orientation [1] screen.
Press [A], [B], or [C] to select the Axis Configuration [2].
Press [4] or [5] to change the physical connection [3].
Press [M], [S], or [I] to set the rotary relation as master, slave, or independent [4].
Press [T], [L], or [N] to set the location of the spindle at either the table, live tool spindle, or main spindle [5].
For this example, the Axis Configuration is Axis A [2], the Physical Connection is the 4th axis [3], the relation is independent [4], and the location is the table [5].
 Note: The rotary direction must match the rotary direction on the image to use Tool Center Point Control (TCPC, G234) or Dynamic Work Offset (DWO, G254).
Press [ENTER] [6].
Press [F3] to Apply the Rotary.
Cycle the power on the machine when you are prompted.
Jog the axis to make sure it operates correctly.
