DT/DM - Spindle Rocker Arm - Spring Installation - AD0205
Service Home How To Procedures DT/DM - Spindle Rocker Arm - Spring Installation - AD0205
6.4 DT/DM - Spindle Rocker Arm - Spring Installation
Recently Updated Last updated: 02/11/2025
AD0205
Applies to machines built from: June, 2009
This procedure tells you how to use the spring mount to install the spring for the spindle rocker. You must install the spring for the spindle rocker when you replace the spindle.
Refer to DT/DM - Spindle Replacement.
Parts Required:
  • ROCKER ARM SPRING MOUNT TOOL DT-1 (P/N 93-2310)
Machine Compatibility
Perform this procedure on DT/DM mills. DT/DM mills made before May 18, 2015 do not have this spring mount installed. The spring mount is necessary to install the spring.
Press [POWER OFF].
Set the main circuit breaker to the OFF position.
Lock the main circuit breaker.
Use an approved lock with an approved safety tag.
Remove the spindle head cover.
Assemble the installation tool for the rocker spring:
  • Put a 3/8 x 1.5" screw [2] into the middle hole of the tool [1].
  • Tighten the screw.
Remove the (2) left screws [4] from the striker plate [3].
Put a washer [5] onto a screw [6] for the striker plate.
Put the tool [2] against the spindle casting, adjacent to the striker plate [1].
Put the screw [6] through the bottom hole on the tool.
Use your fingers to tighten the screw.
Put the rocker spring [3] onto the screw [4] in the middle of the tool.
Use a socket wrench [7] to turn the middle screw [4].
 Note: The tool turns with the screw. It pivots around the bottom screw [6].
Turn the screw until you can:
  • Put a screw [8] through the top hole in the tool and into the striker plate. Use a screw you removed in Step 1.
  • Turn the screw into the striker plate.
Tighten the screws for the striker plate.
Install the spindle head cover.
