    2. Español - ES
    3. Español - MX
    26. Українська
    2. Español - ES
    3. Español - MX
    26. Українська
ST - Tailstock Concentricity to Spindle Correction
Service Home How To Procedures ST - Tailstock Concentricity to Spindle Correction
Recently Updated Last updated: 02/01/2021
- Jump to Section - 1. Introduction (2 steps) 2. Tailstock Concentricity to Spindle Correction (4 steps) Back to Top
This procedure shows how to correct the alignment of the Tailstock [1] to the Spindle Centerline [2].
Refer to ST Lathe Alignment Indicating Zones procedure to measure the Tailstock Concentricity to Spindle Correction. Procede with the procedure if the tailstock needs correction.
Record the amount of misalignment and direction of error.
Note: If the measurement at the base of the tool and the end of the tool are different, refer to ST Tailstock Parallelism to Z Axis Correction. Make the tailstock parallel to the spindle centerline, before you do the steps that follow.
1. Zero the indicator at the bottom.
2. Manually turn the spindle 180 degrees to measure at the top.
3. Look at the indicator to see the direction and the amount of the error.
Note: It is rare that the tailstock requires a vertical adjustment. Check your measurements a second time and make sure your indicator and alignment tool setup are stable.
4. Change the shim size equally on both sides to raise or lower the tailstock centerline. Tighten to approximately half of the specified torque the (4) screws for the tailstock casting.
Note: For torque values, refer to Haas Fastener Torque Specifications.
Note: For shim sizes, refer to: Shim Kit Check List - ST Lathes.
1. Zero the indicator on the side of the alignment tool.
2. Manually turn the spindle 180 degrees to measure the opposite side.
4. Loosen the (4) screws a small amount to let you control the adjustment in the steps that follow.
Note: After you loosen the screws, tighten them enough to let you control the adjustment, but keep them loose enough to let you correct the alignment. This is approximately 5-10 ft-lb (7-14 Nm).
1. Turn each of the two jack screws equally counterclockwise to make space between the jack screws [1] and the dowel pins [2].
2. On the opposite side, turn the two jack screws clockwise. Turn each screw equally to pull the casting equally on both sides.
3. Look at the indicator to see the correction.
4. If the alignment is correct, tighten to approximately half of the specified torque the (4) screws for the tailstock casting.
1. Measure the TIR at the end of the alignment tool.
2. Measure the TIR at the base of the alignment tool.
3. If the alignment is correct, torque the (4) screws for the tailstock casting.
