Umbrella Tool Changer - 10-Pocket Carousel - Motor Replacement - AD0301
Service Home How To Procedures Umbrella Tool Changer - 10-Pocket Carousel - Motor Replacement - AD0301
3.8 Umbrella Tool Changer - 10-Pocket Carousel - Motor Replacement
Recently Updated Last updated: 08/12/2025
AD0301
Revision A 08/2025
This procedure tells you how to replace the carousel motor on a 10-pocket umbrella tool changer.
  1. carousel motor
  2. carousel motor power cable
  3. tool changer proximity sensor
Machine Compatibility
  • VMCs with a 10-pocket umbrella tool changer
 Note: SMM and GR machines with a 10-pocket umbrella tool changer use the same kit ([KIT] 30-2416). To replace a 10-pocket carousel motor on a GR machine, refer to Umbrella Tool Changer - 20/32-Pocket Carousel - Motor - Replacement.
This procedure applies to (4) different kits. You only need (1) motor assembly to complete the procedure.
[KIT]
30-2416
QTY: 1
MOTOR, UMBRELLA CAROUSEL 10 POCKET W/ MECH SENSOR (GR & SMM)
[KIT]
93-1696
QTY: 1
MOTOR, UMBRELLA CAROUSEL 10 POCKET W/ PROX SENSOR (SMM)
[KIT]
93-30-1679A
QTY: 1
MOTOR, UMBRELLA CAROUSEL 10 POCKET W/ PROX SENSOR (MM)
[KIT]
93-1681
QTY: 1
MOTOR, UMBRELLA CAROUSEL 10 POCKET W/ MECH SENSOR (MM)
Umbrella Tool Changer - 10-Pocket Carousel - Motor - Replacement
Push [POWER OFF]. Set the main circuit breaker to the OFF position.
Remove the (8) screws [1] that attach the cover panel [2] to the tool changer carriage. Remove the cover panel [2].
 Note: Covers for the 10-pocket carousel motor have (2) screws on the back of the tool changer carriage.
Disconnect the carousel motor power cable [3]. Disconnect the tool changer proximity sensor [4].
Remove the (4) screws [5] and (4) washers [6] that attach the carousel motor assembly to the bottom of the tool changer carriage. Remove the carousel motor.
Install the new carousel motor assembly to the bottom of the tool changer carriage. Use the (4) screws [1] and (4) washers [2].
Connect the power cable [3] for the carousel motor and the tool changer proximity sensor [4] to their correct locations [5] on the electrical bracket.
Install the cover panel [6] to the tool changer carriage. Use the (8) screws [7].
Unlock the main circuit breaker. Set the main circuit breaker to the ON position.
Push [POWER ON]. Push [POWER UP/RESTART].
Make sure the umbrella tool changer rotates.
