Umbrella Tool Changer - 20/32 - Pocket Carousel - Motor - Replacement - AD0295
Service Home How To Procedures Umbrella Tool Changer - 20/32 - Pocket Carousel - Motor - Replacement - AD0295
3.7 Umbrella Tool Changer - 20/32 - Pocket Carousel - Motor Replacement
Recently Updated Last updated: 08/12/2025
AD0295
Revision A 08/2025
20/32 - Pocket Carousel - Motor - Replacement - Introduction
This procedure tells you how to replace the carousel motor on a 20- or 32-pocket umbrella tool changer, and a GR machine with a 10-pocket umbrella tool changer.
  1. carousel motor power cable
  2. tool-in-position limit switch
  3. tool-1-in-position limit switch
  4. carousel motor
Machine Compatibility
All VMCs
Requirements:
  • VMCs with a 20/32-pocket umbrella tool changer
  • GR machines with a 10-pocket umbrella tool changer, use [KIT] 30-2416
This procedure applies to (6) different kits. You only need (1) motor assembly to complete the procedure.
[KIT]
30-2416
QTY: 1
MOTOR, UMBRELLA CAROUSEL 10 POCKET W/ MECH SENSOR (GR & SMM)
[KIT]
93-7000
QTY: 1
MOTOR, UMBRELLA CAROUSEL 16 / 20 POCKET W/ MECH SENSORS (SINGLE PIN DRIVE)
[KIT]
30-0005
QTY: 1
MOTOR, UMBRELLA CAROUSEL 20 POCKET W/ MECH SENSORS(DUAL PIN DRIVE)
[KIT]
93-30-0005A
QTY: 1
MOTOR, UMBRELLA CAROUSEL 20 POCKET W/ PROX SENSORS(DUAL PIN DRIVE)
[KIT]
93-1685
QTY: 1
MOTOR, UMBRELLA CAROUSEL 32 POCKET W/ MECH SENSORS (DUAL PIN DRIVE)
[KIT]
30-0016
QTY: 1
MOTOR, 50T UMBRELLA CAROUSEL 20 POCKET W/ MECH SENSORS
Umbrella Tool Changer - Pocket Carousel - Motor - Replacement
Push [POWER OFF]. Set the main circuit breaker to the OFF position.
Remove the (4) screws [1] that attach the cover panel [2] to the tool changer carriage. Remove the cover panel [2].
 Note: 10-pocket carousel motor covers have the screws on the back of the tool changer carriage.
Disconnect the carousel motor cable, the tool-in-position cable, and the tool-1-in-position cable [3] from the electrical bracket.
Remove the (4) screws [4] and (4) washers [5] that attach the carousel motor assembly [6] to the bottom of the tool changer carriage. Remove the carousel motor [6].
Attach the new carousel motor assembly [1] to the bottom of the tool changer carriage. Use the (4) screws [2] and (4) washers [3].
Connect the carousel motor cable, the tool-in-position cable, and the tool-1-in-position cable [4] to the electrical bracket [5].
Install the cover panel [6] to the tool changer carriage.
Unlock the main circuit breaker. Set the main circuit breaker to the ON position.
Push [POWER ON]. Push [POWER UP/RESTART].
Make sure the umbrella tool changer rotates.
