Vector Drive - Maintenance
Service Home How To Procedures Vector Drive - Maintenance
13.4 Vector Drive - Maintenance
Recently Updated Last updated: 01/31/2022
Dust builds up around the vector drive and causes the vector drive to over-heat. This procedure tells you how to clean the vector drive.
Haas machines have one of these vector drive types:
  1. Type 1: Smart vector drive, with built-in filter (current style)
  2. Type 2: Smart vector drive, with front cover
  3. Type 3: Smart vector drive, without front cover
  4. Type 4: Classic vector drive
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Push [POWER OFF]. Set the main circuit breaker to the [OFF] position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 60 seconds
Do this step for Type 1 vector drive only.
Open the electrical cabinet door and pull out the vector drive filter [1].
Clean the filter as shown on the decal and re-install it to the vector drive. Close the cabinet door.
Important: Make sure the filter is completely dry before reinstalling it to the vector drive.
Do this step for Type 2 and 3 vector drive only.
Remove the cover [2] and the heat sink cover [3]. The heat sink cover [3] is installed on the top or the front of the vector drive.
Use a vacuum with a brush adapter to remove dust from the vector drive vents [4]. Install the heat sink cover [5] to the front of the vector drive. Do not install it on the top of the vector drive. Install the cover [2]. Examine the weather strips on the door for the electrical cabinet. Replace them if necessary.
Optional: Add a filter to your electrical cabinet door to decrease the amount of dust that enters the electrical cabinet. Go to parts.haascnc.com. Under Find Replacement Parts, search for your Filter in the category Electrical Cabinet
Make sure the Vector Drive operates correctly: Run the spindle for several minutes. The fan on the vector drive will only operate when it becomes hot.
