VMC - Ballscrew - Backlash Test - CHC
Service Home How To Procedures VMC - Ballscrew - Backlash Test - CHC
Recently Updated Last updated: 10/25/2022
- Jump to Section - 1. Tools Required 2. X-Axis Ballscrew - Backlash Test (3 steps) 3. Y-Axis Ballscrew - Backlash Test (3 steps) 4. Z-Axis Ballscrew - Backlash Test (3 steps) Back to Top
Tools Required
  • Dial indicator that can measure 0.0001" (0.003 mm)
Put the dial indicator so that it touches the side of the spindle housing.
Push [X].
Push [HAND JOG].
Push [.001/1].
Jog the X Axis until the dial shows approximately 0.015" (0.38 mm).
Set the indicator dial to 0.
Push [POSITION].
Push [ORIGIN].
In the display, the X value for OPERATOR shows 0.
Jog the X Axis 0.010" (0.25 mm) in the positive (+) direction.
Jog the X Axis 0.010" (0.25 mm) in the negative (-) direction.
Record the difference between these two values:
  • The indicator value
  • The X-Axis position on the control
If the difference is more than 0.0002" (0.005 mm), the backlash is too large.
 Caution: Before you perform the manual backlash test, make sure the machine is not in an alarm condition: Release [EMERGENCY STOP], and push [RESET] to stop each alarm.
Manual backlash test:
  1. With your hands, push on the right side of the table.
  2. Set the indicator to 0.
  3. With your hands, push on the left side of the table.
If the indicator shows more than 0.0002" (0.005 mm), the backlash is too large.
Put the dial indicator so that it touches the front of the spindle housing.
Push [Y].
Push [HAND JOG].
Push [.001/1.].
Jog the Y Axis until the dial shows approximately 0.015" (0.38 mm).
Push [POSITION].
Push [ORIGIN].
In the display, the Y value for OPERATOR shows 0.
Jog the Y Axis 0.010" (0.25 mm) in the positive (+) direction.
Jog the Y Axis 0.010" (0.25 mm) in the negative (-) direction.
  • The Y-Axis position on the control
  1. With your hands, push on the front of the table.
  3. With your hands, push on the back of the table.
Put the dial indicator so that it touches the face of the spindle cap.
Push [Z].
Push [HAND JOG].
Push [.001/1.].
Jog the Z Axis until the dial shows approximately 0.015" (0.38 mm).
Push [POSITION].
Push [ORIGIN].
In the display, the Z value for OPERATOR shows 0.
Push [.001/1.].
Jog the Z Axis 0.010" (0.25 mm) in the positive (+) direction.
Jog the Z Axis 0.010" (0.25 mm) in the negative (-) direction.
  • the indicator value
  • the Z-Axis position on the control
