Side-Mount Tool Changer - Pocket Slider - Set Screw - Adjustment - VMC
Service Home How To Procedures Side-Mount Tool Changer - Pocket Slider - Set Screw - Adjustment - VMC
5.7 Side-Mount Tool Changer - Pocket Slider - Set Screw - Adjustment - VMC
Recently Updated Last updated: 08/13/2025
Revision A 08/2025
If the pocket slider set screw [1] is not correctly adjusted, the cam follower [2] may hit the pocket when the carousel turns.
This procedure tells you how to adjust the set screw for the pocket slider.
VMC - Side-Mount Tool Changer - Pocket Slider - Set Screw - Adjustment
Go into DEBUG mode.
Press [RECOVER] to go into TOOL CHANGER RECOVERY mode.
For software 17.XX and later, press [M].
For software 16.XX and earlier, press [Y] (3) times.
The screen shows Manual Tool Changer Operation.
Press the [RIGHT] cursor arrow to move the carousel forward.
While the carousel turns, monitor the cam follower alignment with the pocket slot.
In this example, the slider is too low.
The cam follower hits the pocket when the carousel turns [1].
Adjust the set screw for the pocket slide, as follows.
Under the pocket stop, find the lock nut [1] for the set screw. Loosen the lock nut.
Turn the set screw [1] clockwise or counterclockwise.
This moves the pocket slider up or down.
For this example, turn the set screw clockwise. This moves the pocket slider up.
Press the [RIGHT] cursor arrow.
This moves the carousel to the next position.
If the adjustment is correct, the cam follower is in the center of the slot.
The cam follower does not hit the pocket when the carousel turns.
If the adjustment is correct, tighten the lock nut [1] for the set screw.
