Magnetic Encoder - Shafted - Installation Aid - CHC - RD0044
Service Home Magnetic Encoder - Shafted - Installation Aid - CHC - RD0044
Recently Updated Last updated: 10/16/2025
RD0044
- Jump to Section - 1. Pulleys and Adaptor Cables 2. Parameter Values and Usage Back to Top
Use the tables below to set the parameters when you install a shafted encoder.
Machine Encoder Pulley
HS Series 20-0042
TL-1 20-0975
OM-1/2 20-3323
EC-630 54-0241
GR Series (5K-GR) 54-0107
GT-20, SL-10, TL-2 54-3090
SL-30L/40L (spindle), SL-40 (spindle), TL-25APL (spindle), TL-3 20-1295
GR Series (complete), GT-10, MDC-500, MM, SMM, TM, VF-1/2/3/4, VF (40T), VR 54-7127
EC Series, ES-5, VF (50T), VFSS, VM, VS, SL-20/30/40 (motor), TL-25APL (motor) 20-0179
Magnetic Encoder Adaptor Cables Description
33-10036 MAG Encoder Molex-6 Adaptor Cable
33-10037 MAG Encoder M23 Adaptor Cable
33-10038 MAG Encoder AMPH Adaptor Cable
33-10039 MAG Encoder Molex-10 Adaptor Cable
The parameter changes below are required when replacing a non-magnetic encoder with a magnetic encoder.
The parameter changes in the table that follows are necessary when you remove a non-magnetic encoder and install a magnetic encoder. Make sure all the parameters are set to the values in the table that follows. If a parameter has a value of zero, do not change it. When you replace a spindle encoder on a machine that has a single encoder, change Parameters 79, 182, 186, 187 and 239.
A lathe can have two encoders: a spindle encoder and a motor encoder.
  1. When you replace the spindle encoder on a lathe that has two encoders, change Parameters 79 and 239.
  2. When you replace the motor encoder on a lathe that has two encoders, change Parameter 182, 186 and 187.
When you replace the encoder on a lathe secondary spindle, change parameters 540, 544, 545, 570 and 571.
Parameter 182 Sp ACCELERATION
Existing New
15000 15360
20000 20480
60000 61440
200000 204800
400000 409600
500000 512000
800000 819200
1000000 1024000
1500000 1536000
1600000 1638400
2000000 2048000
4000000 4096000
Parameter 186 Sp DECELERATION
Existing New
15000 15360
16000 16384
20000 20480
27200 27852
28000 28672
40000 40960
46000 47104
48000 49152
55000 56320
60000 61440
75000 76800
80000 81920
90000 92160
95000 97280
100000 102400
115000 117760
120000 122880
125000 128000
150000 153600
185000 189440
200000 204800
240000 245760
250000 256000
300000 307200
320000 327680
350000 358400
450000 460800
499999 511998
Parameter 187 Sp MOT HI GEAR ST/REV
Existing New
2000 2048
2667 2731
3000 3072
3975 4070
4000 4096
4080 4177
4770 4884
4990 5109
5000 5120
7000 7168
8000 8192
Parameter 79 SPINDLE STEPS/REV
Existing New
1000 1024
2000 2048
4000 4096
8000 8192
20000 20480
Parameter 239 SPNDL ENC STEPS/REV
Existing New
4000 4096
8000 8192
Parameter 540 Ss ACCELERATION
Existing New
1000000 1024000
2000000 2048000
Parameter 544 Ss DECELERATION
Existing New
400000 409600
1000000 1024000
Parameter 570 SUBSPIN ENC ST/REV
Existing New
4000 4096
8000 8192
Parameter 571 SUBSPIN ST/REV+
Existing New
4000 4096
8000 8192
Miscellaneous (All Machines) Miscellaneous (VM, SS, EC&ES/w 12K Option)
Parameter Value Parameter Value
176 - Bit 13 Low Pass 2X 1 176 - Bit 12 Low Pass 1X 0
188 - Orient Gain 500 177 - Sp P Gain 5,500
178 - Sp D Gain 15,000 - -
