Mist Condenser Troubleshooting Guide - TG0103
Service Home Mist Condenser Troubleshooting Guide - TG0103
- Jump to Cause - Back to Top
17.2 Mist Condenser - Troubleshooting
Recently Updated Last updated: 10/14/2025
Mist Condenser - Troubleshooting Guide
TG0103
The Haas Coolant Mist Condenser is a complete closed-loop recirculation system that extracts coolant mist from the machine’s enclosure, runs it through dual mesh filters to condense the coolant, and then returns the condensed coolant and clear air to the enclosure.
SYMPTOM POSSIBLE CAUSE CORRECTIVE ACTION
Loud motor / excessive vibration Damaged motor / imporperly installed rubber bushings Refer to Motor section below
Motor not turning on Wiring  Refer to Electrical Diagram section below
Poor recirculation Clogged mesh filters / incorrect motor phasing
Clean and re-intall filters and verify the phasing on the motor
Refer to Air flow direction section below
Air Flow Diagram
Note : When verifying phasing ensure that the air follow this path or the phasing would need to be switched.
The coolant mist is extracted by the mist condenser through dual mesh filters then returned back into the work envelope through the register back.
Letter Box Fitment Issue (Lathe)
If PN: 25-14616A MIST CONDENSER REGISTER BOX LATHE interferes with the Z-Axis Waycover. Install PN: 25-14616B.
Electrical Diagrams
This diagram only applies to VF machines without Variable Frequency Drives (VFD)
This diagram applies to machines with a TMD card.
The mist condenser is powered by the TMD card, the mist condenser will connect to P1 on the TMD card. The TMD card will connect to the I/O board via P69. The TMD card will be powered from the transformer and will connect to P4 on the TMD card.
Note : Make sure that TMD card has a jumper installed on P3 in between pin 1 and 2 (the bottom two pins).
Motor
Verify that the rubber bushings [1] are properly seated and are not damaged.
Note : Damaged bushings will lead to excessive vibrations to be transmitted to the machine which may sound like a failing motor.
Verify that the ground wire [5] is fully tightened and properly seated.
Ensure that wires are fully seated into the lever nut connectors [4] and [3].
