Multi-Stage Pump (MULTI-STAGE CLT PUMP)
Product Image
GET QUOTE
Multi-Stage Coolant Pump
    CNY ONLY
More flow, more pressure, less noise
  • Quieter than the single-stage pump
  • Built-in filter screen on the pickup tube
  • 1.5 hp (1.1 kW) pump
  • Higher flow and pressure
  • Option Info
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
Our multi-stage coolant pump uses a series of stacked impellers to provide more flow and higher pressure than the single-stage coolant pump, while offering much quieter operation.
  SAE Metric
Power 1.5 hp 1.1 kW
Flow Rate 60Hz 16 gpm @ 70 psi 61 L/min @ 4.8 bar
Pressure 60Hz (outlet) 70 psi 4.8 bar
Pressure 60Hz (spindle) 40 psi 2.8 bar
Deadhead Pressure 60Hz 130 psi 9 bar
Flow Rate 50Hz 14 gpm @ 50 psi 53 L/min @ 3.4 bar
Pressure 50Hz (outlet) 50 psi 3.4 bar
Pressure 50Hz (spindle) 30 psi 2.1 bar
Deadhead Pressure 50Hz 95 psi 6.6 bar
SERVICE DOCUMENTS
Need More Information?
