EU Sub-Spindle Package (SUB-SPINDLE PKG-EU )
Product Image
GET QUOTE
EU Model Sub-Spindle Package
    CNY ONLY
Available for ST series EU models
  • A2-5 Spindle Nose
  • Hydraulic Chuck Type
  • Servo Drive
  • Option Info
  • Torque Chart – ST-10Y/15Y/20Y-EU
  • Torque Chart – ST-30Y-EU
OVERVIEW
SERVICE DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
Our Sub-Spindle Package for EU Model Y-Axis turning centers will not only make your machine more productive, but also will provide new options for finishing the 2nd-op side of your parts.
The package includes a servo-driven A2-5 finishing sub-spindle with hydraulic chuck, an air blast system to keep the chuck and workpiece free of chips on both the main and sub-spindle, and our CNC control cabinet cooler to keep the electronics running efficiently.
The sub-spindle fully synchronizes with the main spindle to provide effortless “in-cycle” part handoff, allowing you to finish the “other half” of your part in a single setup. A built-in part ejector propels the finished part into the optional parts catcher for automated operation.
Package Includes:
  • A2-5 finishing sub-spindle
  • Main spindle air blast (JET)
  • Sub-spindle air blast (SUB-SPINDLE JET)
  • CNC control cabinet cooler (CABCOOL)
FEATURES: ST-10Y-EU, ST-15Y-EU, ST-20Y-EU
  • 6000 rpm
  • A2-5 spindle nose
  • 5.3" (135 mm) hydraulic chuck
  • Powerful servomotor drive provides generous torque throughout the rpm range
  • Allows fully synchronized part pass-off (up to 4800 rpm)
  • Built-in part ejector
FEATURES: ST-30Y-EU
  • 4100 rpm
  • A2-5 spindle nose
  • 6.5" (165 mm) hydraulic chuck
  • Allows fully synchronized part pass-off (up to 4100 rpm)
Service Documents
VIDEOS
The Finishing Spindle In Action
Watch live tool milling, drilling, and tapping, featuring our A2-5 finishing sub-spindle and ST-10Y turning center.
Use G14 to Program Your Lathe Sub-Spindle
See just how easy it is to program your lathe sub-spindle. In this Tip of the Day, Mark walks you through how to use G14 and how to set up your tools when using a sub-spindle.
Sync Your Spindles with G199!
In this Tip of the Day, Mark shows how to synchronize the spindles on your Haas dual-spindle lathe. Learn how to hand off parts from the main to the sub-spindle, how to orient the chucks, and how to be sure the RPM on each spindle matches. With a great step-by-step explanation combined with some great animations and close-up shots of the spindles, you will walk away from this video an expert in spindle synchronization!
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Note:
Need More Information?
