10k Inline Spindle, 60 hp (10K-50T-IN-HP)
Product Image
GET QUOTE
High-Performance 10,000-rpm Spindle
    CNY ONLY
High-speed 50-taper inline spindle
  • 10k Speed
  • 50 Taper
  • 60 hp Power
  • Inline Drive
  • Option Info
  • Torque CHart
  • Specs
OVERVIEW
DOCUMENTS
AVAILABLE ON THESE MACHINES
This high-performance 10,000-rpm inline 50-taper spindle provides 33% more speed than the standard spindle for higher cutting speeds and surface feedrates. It features a 60 hp (44.7 kW) vector drive system that provides high power and torque throughout the rpm range. The compact design of the inline direct-drive system simplifies service, and provides smooth, quiet operation.
  • Inline direct-drive spindle – designed, manufactured, and built in-house
  • 60 horsepower (44.7 kW) vector drive system
  • High power and torque for larger diameter tools and tough materials
Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Spindle S.A.E METRIC
Max Rating 60.0 hp 44.7 kW
Max Speed 10000 rpm 10000 rpm
Max Torque 170.0 ft-lbf @ 1800 rpm 230.0 Nm @ 1800 rpm
Taper CT or BT 50 CT or BT 50
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Spindle Speed 10000 rpm 10000 rpm
Spindle Power 60.0 hp 44.7 kW
Full Load Amps (3 Phase) - Low 105 A 105 A
Need More Information?
