Sub-Spindle, A2-5, 8.3" Chuck (SUB-SPDL-A2-5-8.3)
Product Image
GET QUOTE
A2-5 Secondary-Spindle, 8.3" Chuck, 4000 rpm
    CNY ONLY
Fully interpolated C-Axis w/brake
  • A2-5 Spindle Nose
  • 8.3" Chuck Size
  • 4000 rpm Speed
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This A2-5 secondary-spindle for the DS-30Y is equipped with a 8.3" (210 mm) hydraulic chuck, and will fully synchronize with the main spindle to provide effortless “in-cycle” part handoff. This allows you to finish-off the “other half” of your part in a single setup – simply load up your raw workpiece, and the next time you open the door, you’ll have a finished part. The secondary-spindle has a full C-axis for accurate positioning and interpolated live-tooling operations, and a mechanical brake that provides 140 ft-lb (190 Nm) of holding torque for off center milling and drilling.
  • 4000 rpm
  • A2-5 spindle nose
  • 8.3" (210 mm) hydraulic chuck
  • Fully interpolated C-axis with brake
  • Allows fully synchronized part pass-off (up to 4000 rpm)
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
